Question about HP Computers & Internet
My cd / dvd drive will play dvd's but will not play cd's. why?
  • HP Master
  • 27,725 Answers
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 26, 2011
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I don't know how to download cd's and dvd's on dell EL-1210-09
What do you mean download cd's and dvd's? You don't download them, you simply put them in the drive and play them. If you purchased a music cd or a movie dvd that you want to play or watch, then just put it in the drive. The system will recognize it and automatically open Windows Media Player for you to play it or you can open it yourself if autoplay is not active.
Exactly what is it that you are trying to do?
If you are talking about putting a blank cd or dvd into the drive to copy music or a movie to it, that's another story and will take a while to explain. You will basically need to make sure your CD/DvD drive can burn CD's or Dvd's. Then you will need some type of burning software (later versions of Window Media Player will burn).
Click Start/My Computer and look at your devices. if your DvD/CD Drive is listed look for RW which means rewritable (it can burn or copy). If it say DVDrw it can read and write dvd's. If it says CDrw it can read and write cd's. You can also look on the drive door on the computer where you would place the cd or dvd. If it says Rewritable CDrw (it can write cd's) or DvDrw (it can write dvd's). If it says ROM (read only media), that means it can Read Only and not write.
If the drive is rewritable then the software such as Media Player will allow you to go find what you want to put on the cd or dvd. You have two ways of putting things in the software to burn or write. You can copy and paste, or you can drag and drop.
May 13, 2012 | eMachines EL1210-09 PC Desktop
Please help, my ''Slimtype DVD A DS8A3S ATA Device '' won't work.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
May 01, 2012 | Computers & Internet
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
I have a dell 755 that the CD drive won't play certain CD's. It is not the CD because it plays on other machines. Some CD's will play just fine. Get's the error message Unable to Access Drive D tr
it depends on the files on the cd ...they might require a certain software to be installed in order to be read..for example the player may not be able to read mp4 without a codec installed ..or vcd (video cd ) to need a dvd player installed or a player that supports video cd and dvd-es..Same way for other file types...or ...certain speeds being imposed on writing ..and your cd drive to be unable to read them on those speeds..
Nov 09, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
My computer says that it has Cyberlink DVD 9 on it. But I can't play any DVDs on it. What shall I do?
First, gotta make sure you have a DVD drive, most modern computers do: DVD, DVD/ CD-RW, or DVD-RW drives are commonplace these days. If you have a DVD drive and it doesn't play anything, then more than likely you have a defective drive (DVD drives not working with DVD discs is a fairly common type of failure - insofar as failures go).
To be absolutely certain, try playing an original, commercial DVD movie - one that you know is good - if it still doesn't play it then it is, in all likelihood, a failed DVD drive.
Sep 01, 2011 | Computers & Internet
My CD/DVD drive is not reading Rosetta Stone - Espanol Edition. It stars and spins, but then stops. OS: Vista SP2 Disk Drive: Unknown RAM: 3 GB - DDR2
Try playing a music CD to see if it works. Then try playing a DVD ( a DVD movie ) and see if that works. If the CD works and the DVD doesn't then your CD/DVD drive is probably the problem and needs to be replaced.
Jun 24, 2011 | Dell XPS 410 PC Desktop
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Hi I have cf-19 I need to install mapping software that requires a resident cd drive to install. Will any usb cd/dvd drive work?
As long as it is a plug&play drive it should work just fine. It's hard to install a USB CD/DVD Drive that isn't plug&play.
May 02, 2011 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
