Question about Frigidaire Hardware & Accessories
Have frigidaire gallery range model fed387cfsa installed in 1998. Used in beach house, but the display has never been highly visable. The lighting for the LED numbers cannot be seen which makes it very difficult to read the temp settings, time, etc. What can be done to increase the light of the LED numbers?
huuum
  • 750 Answers
SOURCE: Frigidare Gallery Range 1998 model convection/baking drop in range
Hi Juliett
huuum At your service!
You said,
You came home and the was no display showing - control panel seems completely dead - last time we used the stove the display was so dim it was hard to see.
_______________________________________________________________________________
I advice that you are correct!
From what I have read it sounds like a board should be replaced and the cost would be roughly $450 - is it worth it to call a tech or should I just buy a new one.
This like an expensive repair for an old range!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Buy New and save!
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Frigidaire has some good rebates this month!
Some Up to $750. cash back
Bless You,
huuum
Please give me a solved rating for this good advice at our web site before you sign off!
Posted on Sep 13, 2008
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
SOURCE: I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Posted on Dec 24, 2008
vanni7
  • 163 Answers
SOURCE: Display too dim to read
Hi!! you seem to have a bad control board its on the back top panel its shorting out.replace ut and you should be fine..Good luck..
Posted on Jan 04, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Frigidaire gallery gas range temperature display lights are very dim
Hello Peter Robinson - If the display LED's are dimmed on the range but it is working, then it sounds like more than likely the EOC (electronic oven control) or wiring failure will need replacing. I personally recommend contacting a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified provider by visiting the manufacturer website.
Mar 04, 2013 | Frigidaire Gallery 30" Self-Cleaning...
I have the Frigidaire Gallery slide in stove/oven. The display for temperature is so dim that I can't see it anymore. Would it be a fuse?
The Electronic control has lights inside for the time and for the temperature. Over time the lights get dim (Frigidaires do it a lot). The Electronic control is not a Servicable part. You must buy a new Electronic control.
Apr 09, 2012 | Kitchen Ranges
Hi Juliett
You said,
Buy New and save!
Bless You,
huuum
Sep 13, 2008 | Frigidaire FED367 Electric Kitchen Range
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Dec 18, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Hardware & Accessories Logo
20 people viewed this question
Top Frigidaire Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Frigidaire Hardware and Accessory Expert? Answer questions, earn points and help others
