Question about Garden
NEED BELT DIAGRAM FOR SNAPPER REAR TINE TILLER. MODLE TR8 1988 YEAR OF MAKE. BELT WAS OFF THE PULLIES WHEN I TRIED TO PUT ON NEW ONE. NEED DIAGRAM OF HOW IT GOES ON PULLIES.
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Posted on Apr 25, 2009
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Posted on May 06, 2009
  • 3 Answers
SOURCE: belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
Posted on May 12, 2009
I have a Snapper RT8 tiller that needs a new belt. What type and size of belt does it take and is there a schematic for routing the belt.
you need the model number on the tiller should be a tag on it somewhere and sometimes the serial number as well to get the right size
Oct 16, 2011 | Omega Rear Drive Wheel Snapper Mowers
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
Apr 14, 2011 | Troy-Bilt Garden
I have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Mar 22, 2011 | Craftsman Garden
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Mar 11, 2009 | Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
