My mouse was not function then a warning sign appears code 43.....
    Sergeant:
  • 167 Answers
You received error code 43 because the usb device is not in good condition or have a defect try to use a good one, so it will not harm your unit
Posted on May 26, 2011
  • 51 Answers
Which operating system is that?
91 3.1 car starts and runs fora minute then dies code 43 came up( fixed wire kn Sen.) now 21and 43 came up?
You didn't say what the make and model are, but if code 43 is a knock sensor issue I guess its a GM product.
Code 21 means the TPS voltage was too high, and code 43 means the knock sensor voltage was too high or too low.
Neither code would kill the engine. Just turn the warning light on.
If the throttle position sensor failed, you would get the effect of stalling on acceleration.
You may need to narrow down the possible causes to spark or fuel, and in the end it could be the engine computer. It could also be a relay or other electrical component.
Apr 08, 2016 | Cars & Trucks
WHERE DO I FIND DRIVER ON LINE TO INSTALL FOR MOUSE
Try the following site for mouse drivers.
Trust this helps, regards Alan
http://www.microsoft.com/hardware/en-au/downloads
If re-installing the driver does not fix the code 43 error, you may like to browse through the following:
Are You Seeing Code 43 Error Here What You Need to Do
Apr 15, 2015 | Computers & Internet
Gm obd1 codes 32 and 43
Code 32 is a problem with the EGR solenoid, and code 43 may be a problem with the knock sensor. Code 43 can set when the knock sensor is functioning correctly too.
You would need to get the troubleshooting charts for the codes to determine the problems.
Jul 11, 2014 | 1992 GMC Sierra K1500
Error code 43 on dell computer
Error code 43 is when a dll sends a message that a blue tooth device has failed. most likely your courdless mouse or keybord is the culprit. try removing it from device manager and reinstalling it.
Jun 01, 2014 | Dell OptiPlex 170L PC Desktop
No start code 43 and 54
code 43 knock sensor signal
54 Fuel pump circuit - voltage low Wiring open circuit/short circuit to ground, fuel pump relay, fuel pump, engine oil pressure warning lamp switch, ECM hope it helps
Apr 01, 2014 | 1992 GMC Yukon
Exclamation marks is red on dashboard, diagnosis shows code 171 and 174
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
So why does another fault light come up when brake pedal pressed ,Try reading the codes again with a diagnostic tester that has the relevant codes built into the machine and not a micky mouse device
Nov 29, 2013 | 1999 Ford Ranger SuperCab
Warning sign of "ADS" appeared
you mean abs not ads stands for anti brakeing system have your checked its throwing a code have fixed then light will go off its telling you somethings wrong somewhere in your brakes
Feb 12, 2011 | 2000 Pontiac Montana
Fix code 43 for dell inspiron 1501
You may have to go to Dell Website. http://www.dell.com.au Go to support then in the search type in Fix Code 43. Comes up with approximately 25 solutions, I am fairly sure one will suit you. These are drivers etc to update your system.
Jan 22, 2011 | Dell Inspiron 1501 Notebook
T-43 Laptop - Screen freezes, mouse freezes, all functions stop..
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
Jan 21, 2010 | IBM ThinkPad T43 Notebook
A warning light appear with my hibrid prius
I have same engine problem. Triangle signal pop up after I try to start my Prius with a still wet air filter to the car . The engine just run for less than 30 sec. and stopped with the triangle signe pop up. I think this sign will pop up whenever the engine detect certain major function failure. For my case, it was due to retricted air supply to the engine. I have tried Lovebytes suggestion and the triangle sign disappeared with a dry clean filter. My Prius is running good now. This warnig sign may have other implications. Once you try this method and sign still come on. You need to have your car check by garage.
Bellow attach is the answer from Lovebites
cc1dd82.jpg Lovebytes
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
Jan 05, 2009 | 2001 Toyota Prius
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
