Question about Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System
I need the default password for the SU2200RTXL2U ups?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
User Name: apc
Passwork apc
You must have a network card installed to log into the UPS. Also You must use a 940-1524 APC cable. There is no other way then this. Use putting to log in.
Posted on Oct 07, 2014
Where do I get the code
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings.
Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all.
As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else.
You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed.
Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
This can be done by opening your internet browser (i.e. Internet Explorer, Firefox, Safari, Opera, etc.) and typing in the address bar 192.168.1.1.
Once you hit enter, an authentication panel would pop-up requiring you to enter a username and password.
Note: If entering 192.168.1.1 does not bring up anything, your default gateway may not be that.
For Windows, just go to Run command (Windows Start button, then click Run), and then type "CMD".
A DOS prompt would pop-out and you would just need to type, "IPCONFIG". Look for the words "Default Gateway", the numbers beside it are the ones you need to enter into your browser
Usually, its 192.168.1.1 or 192.168.0.1 so most likely you wouldn't have to do that.
Another Note: The usual username and password is "admin" (without the quotes).
For some routers, the username is admin, and the password is blank.
Jan 09, 2014 | Computers & Internet
What is the password for a powerware?
You will have to consult the user manual for the default password. Usually default passwords are admin/admin.
Oct 16, 2013 | Powerware 9390 UPS System
Trying to set up wifi on new phone and its says need password and i dont remember setting one. so can't get access to internet
The default password of the router is admin. If you have set up a password before, it will not recognize the default admin.Hold the reset button (at the back) of the router for 10secs and it will retrieve the default admin...To change the default password, lauch internet explorer(pc should be connected to the router hardwired), type on the address bar, 192.168.1.1--it willl prompt for a username and password, leave username blank and password will be admin...It willl bring you to the set up page of the router..click on the administration tab and from there you can create your new password for your router.
Oct 29, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
I lost my password to my netgear, to hook up my second computer?
You don't need a password to hook up a second computer - just plug it in. You only need the password if you want to change the configuration of the router.If that's the case, the default user ID for this model is 'Admin' and the default password is 'password'. If you have a non-default password you will have to reset the router to factory defaults and then login with the default ID/password.
To reset to factory defaults, press and hold the Reset button until the Test LED turns on (about 10 seconds). Release the Default Reset button and wait for the router to reboot
Feb 19, 2011 | NetGear WGT624 Wireless Router
I forgot my password
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Password
Are you trying to access the router set up.
There is not default user name for the router. Keep it blank. the default password will be " admin ". If that doesn't work the router password must be changed. Try some of your passwords and see if that opens the set up page. If nothing is woirking then you will need to reset the router and set up the router again.
Click here for more information about routers
Jul 13, 2009 | Computers & Internet
Linksys router G - buddy forgot password I am at my brother-in-laws home for the week and they don't know the username and password for the linksys but they do have custom settings. How can I just reset...
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Jul 01, 2009 | Linksys Wireless-G WRT54GS Router...
Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Jun 03, 2009 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
Need Username and password to setup
it's unusual for a default password to be used bur tr typing 'password' as the password
Apr 01, 2007 | Actiontec GT704WG Wireless Router...
Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System Logo
487 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
