Question about Garden
The pull string will not retrack, only ran it once, it stalled and tried to go through steps and pul string won't come out.
    Novelist:
  • 184 Answers
Find the little oil hole on top of the starter bracket. Squirt some "TriFlone" oil in there and tap the center of the starter with a big screwdriver handle. It should pop right back in -watch out for the rope handle-
If it doesn't- leave it parked in the sun- and by morning the temp change will probably release it. (this called "Spring Bound". in case you want to talk to a mechanic about it.
The worse case is the spring broke. That requires the removal of the starter and fitting a new "rattlesnake" back in there. You will understand that term if you try to do it yourself. But everybody started down the mechanic trail somehow.
Posted on May 26, 2011
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
1995 Nissan Sentra stalled while driving, replaed air sensor, battery and starter, still won't start
Can you hear the starter cranking the engine over?
Have you checked for spark?
Have you checked for fuel pressure?
Feb 09, 2013 | 2001 Nissan Sentra
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
CODE P0101 AND CODE P0341 i have a 96 chevy blazr 2dr 4x4 4.3L. I RECENTLY HIT A LARGE BUMP AND THE TRUCK STALLED.PULLED OVER AND STARTED IT BACK UP .IT RAN A SECOND OR TWO THEN STALLED AGAIN. IT WASN
Well the code 101 is for the MAF sensor and code 341 is for the cam sensor if equipped.
I'm showing a distributor for that engine so its possible something is going on inside of it.
My first guess would be something in the engine harness that was jarred loose.
You might have to test the circuits at the ECM to see if anything is not making the circuit back to it.
If the engine won't idle and the MAF code is present, you could have a large vac leak somewhere.
Jul 10, 2012 | 1996 Chevrolet Blazer
Pull cord frozen
if it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
May 19, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
Will start but it won't stay on once I step on the
not getting air or exhaust ....its being 'choked'
Nov 01, 2011 | 1989 Jeep Cherokee
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Just replaced engine in 1995 bonneville, with newly insatlled timing chain and gears.drove about 10 miles before stalling out. started back up and ran really rough like it was missng for a minute or two...
need to pull the balancer off and check the crankshaft sensor for damage. sounds like the fins on the balancer may have gotten bent a little and rubbed through the sensor.
Jul 27, 2011 | 1995 Pontiac Bonneville
When pulling the string to start the weed eater it feels as it's locked and won't pull out more than an inch I have set it to full choke half choke also primed it nothing works how do I get it...
If this is a 2 cycle engine , which most weed eaters are, then it sounds like probably the piston is locked up inside the cylinder. Try taking the spark plug out. if it still will not pull out then take the recoil cover off. There should only be 4 screws holding it on. Once you get that off see if the string pulls out of recoil if it does then check to see if you can turn the crank on the engine.If the recoil string does not pull over then that needs to be repaired or replaced. If the crank on the engine will not turn over by hand then your engine is siezed. If you take the covers off to expose the exhaust there are 2 bolts that hold it on take those out and look inside. If you see vertical scoring on piston then your machine isnot worth fixing
May 15, 2011 | Garden
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
May 21, 2010 | Craftsman Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
