Question about Canon PIXMA iX4000 InkJet Photo Printer
Canon mp530 pixma check printer error 6500 - Canon PIXMA iX4000 InkJet Photo Printer
  • 51 Answers
It may be the cartridge...try removing it and then reseating it. If that doesn't do it, clean the contacts with water or isopropyl alcohol.(power off when you do this)
maybe this forum will explain more
http://www.fixyourownprinter.com/forums/laser/13864
Posted on May 26, 2011
5 Suggested Answers
uxair shah
  • 812 Answers
SOURCE: canon MP530
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Posted on Apr 06, 2010
SOURCE: canon pixma mp530 problem error code 5100
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
geemarie
  • 876 Answers
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
  • 2385 Answers
SOURCE: Canon PIXMA MP530 All-In-One InkJet
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Posted on Dec 15, 2010
Printer blinking error 6500 help
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Sep 13, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Mar 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 error 6500
  • Properly seated
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Hello
Good Luck
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mp530. Error 5C00
it means Purge cam sensor error
visit this link for more info and possible solution
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 error code - "Check Printer 6500"
  • Properly seated
Best of luck
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA iX4000 InkJet Photo Printer Logo
625 people viewed this question
old marine
old marine
