Question about Speed Queen AES17AWF Electric Dryer
How to replace the dryer belt? Do you take off the top of the machine?
    Brigadier General:
  • 3,301 Answers
Check this site http://repair2000.com/wpoolbelt.htm and if you need more info,, you could check here its the PDF for your model with a download http://www.retrevo.com/support/Speed-Queen-AES17AWF-Dryers-manual/id/14008ci356/t/2/
Posted on May 26, 2011
How to troubleshoot noise coming from dryer
A whining noise could be either a worn drive belt on it's way out or a piece of clothing trapped at the back of the drum. To check this, you can unplug the machine, unscrew the lint trap on top of the dryer and using a flathead screwdriver, pop the top off the dryer. Once the top is up, you should be able to inspect the drive belt and be able to feel around the back of the drum for any debris or clothing. If the belt requires replacement, you will need to unscrew the front of the dryer to get the front panel off.
Dec 16, 2011 | Whirlpool Washing Machines
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
Aug 02, 2011 | Washing Machines
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
I need to replace the broken belt on my dryer. Its a Frigidaire Dryer Model GLGR341AS4 The model of the belt is : WCI-134163400 AB I was able to remove the cover that exposes the motor and diagnosing the...
Unplug the dryer. Using a one inch paint scraper you can locate the two spring loaded clips holding the top in place. They are located about one inch in from the top corner of the cabnet between the cabnet and the top. Depress the clips one at a time lifting on the corner of the top,tilt the top back and rest it on the wall.Inside the dryer cabnet looking down you will see two screws, one on each side holding the front panel to the cabnet. Remove the screws and tilt the front panel forward. Mark and remove the wires going to the lid switch. Remove the front panel. Remove and discard the old belt. Slide the new belt over the drum with the grooves on the belt facing the drum. Reassembe the front panel of the dryer and replace the wires onto the door switch. Replace the two screws on the front panel. Reach into the rear access panel and grasp the belt. Pinch the belt and feed it under the pully of the belt tentioner. Pull the belt tentioner towards the motor pulley and slide the pinched part of the belt over the motor pulley.
Replace the inspection panel on the rear of the dryer.
Lower the top and press down to lock it into place and your done.
Jan 21, 2010 | Dryers
The dryer heats but will not tumble. I am
if the belt was broken, the safety switch would shut off the machine. the belt is probably slipping, stretched from age. replace belt
Jul 09, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Mar 14, 2008 | Dryers
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Speed Queen AES17AWF Electric Dryer Logo
247 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
