Question about Bosch Nexxt 800 WFMC8401UC
Hello. I have the 09 model. A buzzer sounds when
Hello. I have the 09 model. A buzzer sounds when I try to start it, and it will not start. I thought it was a problem with the door latch, although it seemed to be tightly closed. No warnings came up on the display screen. I called a local appliance repair tech who checked it out and said the door latch and fittings were all OK, and that it was "probably the computer". He priced out a replacement at $850. That's a lot of money to pay for a "probable" component. Any suggestions?
  • Bosch Master
  • 2,605 Answers
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Bosch washer, however I'm at a bit of a loss as to why the quote was so high...even with labor I usually charge around $$250 - $300 canadian dollars.
Indeed it could be a control and it does sound likely, but any modules I've changes are either under warranty (you may want to check, parts have 2 years excluding labor through an authorized servicer) or cost about $150 as you can see if you click on this link.
http://www.searspartsdirect.com/partsdirect/part-number/Bosch-Parts/Washer-Parts/665847/0026/630/Model-WFMC8401UC13/1794/0153200?keySuffixId=NA&productTypeId=x&searchModelNumber=WFMC8401UC13&subCompDesc=Control%20panel&brandDesc=BOSCH&modelDesc=WASHER&blt=11
So there never was any error code displayed correct ? Sounds like a control but I'll need to clarify the model number before detailing much of course but that is based on your initial post. I'll need to watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on May 26, 2011
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
No more buzzer sounds
replace the buzzer
also you didnt place maker or models details
however a no brainer
the buzzer unit is beyond fixing
dont use it till you replace the buzzer indication of ready... etc
next time post make and models please otherwise its as long as a piece of string too follow you..???!!!...
Mar 04, 2015 | Washing Machines
What would cause my 95 ford aerostar not to start but the buzzer work so I don't think it's battery
Buzzers don't need much juice to buzz. Charge the battery first and try again. Could be neutral/park interlock switch bad, bad starter....
Sep 12, 2014 | 1995 Ford Aerostar
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
Buzzer do not stop in samsung washing machine
What is the model number of the unit?
Nov 07, 2012 | Washing Machines
Kenmore out of balance buzzer
What is the model number?
Oct 17, 2012 | Washing Machines
My intertherm outside unit is clicking and I can hear a buzzer every so often. When the buzzer goes off the inside lights dim for a second. Model T5BD-048K and serial # T5A060500118. Product p3ra-048k is...
Sounds like the compressor is trying to start but is not. The lights are dimming as the unit is overamping. The buzzing noise is the motor trying to start and failing. The click is the unit going out on it 's safety device, unually an internal overload.
Hope this helps.
Feb 06, 2010 | Intertherm P3RA-048K Air Conditioner
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Bosch Nexxt 800 WFMC8401UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
