Question about Pyle PLTS77DU Car DVD Player
How do i connect the pyle license plate back up camera to the plts77du car player?
    Problem Solver:
  • 45 Answers
ON THE BACK OF THE UNIT YOU SHOULD FIND A RCA CORD WITH A LABEL ON IT THAT SAY'S CAMERA HOOK THAT VIA RCA TO THE BACK UP CAMERA YOU'LL PROBABLY NEED A 17-20 FOOT RCA. IF THERE IS NO CAMERA INPUT USE THE VIDEO AUX IN
Posted on May 27, 2011
Pyle plts77du
they are set this way so you cannot watch any dvd while car is operating for safety reasons
Mar 24, 2014 | Pyle PLTS77DU Car DVD Player
I have a pyle plts77du. it was playing for about 20 min then i trun off the car. i push it back to mont it and trun the car back on then nothing happend..... like a little red light come on then went...
Its possible the connections From you Remote Wire are not fully tight.. Same goes with The Ground and positive,,,
I would remove and redo all connections..
Even as Far as re stripping the wire for best connection
May 09, 2011 | Car Audio & Video
How do you disconnect the safety thing for watching a movie and driving?
These things are usually wired into the gear selector electrical switches but easiest way is to try removing one wire at a time unless of course you have a wiring diagram for it that shows a connection of the gear switch system
Apr 28, 2011 | Pyle PLTS77DU Car DVD Player
There is a black power cable with two leads for the power for the camera but I don't have in the instructions what to do with it
This is how to hook up the Pyle PLCM7300BT:
On the license plate camera, plug the black cable provided with 2-wires inside (one red and one black) to its counterpart on the camera. On the open end of this black cable, strip and connect the black wire to the car/truck metal body part.
Connect the red wire from the camera and the green wire from the monitor (part of the big black cable from the monitor) to the power wire to the back-up lamp socket.
Connect the Red wire from the monitor to a switched terminal on the fuse box so that it would only have power when you have the ignition key on.
The rest of the wiring is simple and common sense.
To operate, turn on the ignition of you car/truck and put it on reverse you should see the camera view. Put the car/truck on Park, the monitor screen should go back, if not, push the power button once.
To set up the blue tooth: Push the power button on the monitor so that you can see the blue screen and "no Input". Put your phone on discoverable mode and push scan for device. AT the same time push the "pair" button on the monitor.
I did all the figuring out on the bench using a 12 VDC power supplies and contact switches to make sure I understood how it worked. Once installed on my 1988 Suburban, it worked as expected.
The only problem I had to patch the long green wire (reverse car) so that it reached the back-up light socket.
Let me know if you still have problems. Email me at wayne.tan@wdc.com
Wayne Tan
Feb 24, 2011 | Pyle PLCM7300BT Mirror Monitor
Im not sure which plugs I should plug my RCA cables that come from my amp to the reciever. I dont know if its the "back RCA output" or the "Front RCA output" or the "subwoofer...
First of all get yourself a Y-LINK cable. (single male RCA on one side/ double female RCA on the other side) Connect the Y-LINK to your head unit sub woofer output with the stereo RCA that leads to the sub woofer amplifier. Now you are connected to the correct output. I do not know what head unit you had connected before to base your comparison, however there is a output voltage difference from one head unit to another, (1.2V, 2V, 2.5V, 4V, 5V) and that is what determines where the gain on the amplifier should be set to. Always match the headunit output voltage with the amplifier gain control to be the same. It is not uncommon for some entry level units to have a single sub woofer output. dreamsystems
Feb 21, 2011 | Pyle PLTS77DU Car DVD Player
The problem is everytime i turn my head lights on the pyle swiches to a blue screen, the radio goes off and it has the words "car" in the top left corner of the blue screen. i own a 2004 ford...
you have your wiring wrong, im guessing you have a rear view camera on there, you need to dissconnect the wire thats for the rear view camera (behind ur dvd) get another wire , connect one end to your backup lights (12v, red) and connect the other one to the wire for the camera behind ur dvd player
Nov 28, 2010 | Pyle PLDN76DB Car Video Player
THE SCREEN IS OUT ,DON'T FLIP UP AND GET BACK TU THE STEREO
Pyle PLD7MU Car DVD Player - Reviews, Features, and Prices $186 ... Save time and find great deals on Pyle PLD7MU Car DVD Player. Product reviews, details, and features for Pyle PLD7MU.
www.dealtime.com/Pyle-PLD7MU/info - Cached TRY THESE GUYS .... PLEASE RATE MY HELP AND GOOD LUCK
Nov 23, 2010 | Pyle PLD7MU Car DVD Player
I have a pyle pld5mu and the screen is dark
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
Shawn Contreras
Jan 08, 2009 | Jensen VM9510 Car DVD Player
Pyle PLTS77DU Car DVD Player Logo
204 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
