Question about Canon PIXMA iP4000 InkJet Photo Printer
My black large black ink cartridge is not printing. (BcI-3ebk) I have done all the cleaning suggestions and put in a new cartridge. Still nothing..
    Scholar:
  • 118 Answers
Unfortunately you have a blocked defective printhead. You could try removing the ink cartridges, remove the head and then dip the tip of the head into hot water for a minute or two. Dry the head, re install and run cleaning cycle again.
This does not work very often. You probably will need a new printhead and they cost more than a new printer.
Posted on May 26, 2011
What is the ink cartridge numbers for the MP730?
Here are the codes for your cartridges: BCI-3eBk (Black), BCI-3eY (Yellow), BCI-3eC (Cyan), BCI-3eM (Magenta)
Dec 28, 2010 | Canon SmartBase MP730 All-In-One InkJet...
I think I put in a wrong colored toner cartridge. Pages printing in wrong colors. Can't find a list of the cartridges I should be using.
The make and type of cartridge is generally given in the users handbook/manual provided with the printer. If you do not have that ,you can log on to Canon web site and then go to support. Select your printer model and you can find the the specification of cartridge to be used with your printer. The list of the cartridges is given below: BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank You can also go the this link and download the manual if you do not have the same http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#Overview
Nov 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Replacing ink in the Canon BCI-3eBK Ink Cartridge
Hi Albert
Only do this if you are desperately keen to black ink all over your hands and desk.
I did it for a year, refilling all the cartridges. I never once managed to keep my hands clean. In the end my print-head died. It didn't like the black ink and I had to replace it. Now, despite the cost, I only use genuine canon cartridges.
If you are still keen, then you have to drill a hole in the top of the cartridge. Do it in the area where it says push. If you do it in the area above the sponge it will all go wrong afterwards. You must also block up the big hole in the bottom where the ink comes out (that's were you get all messy) and then use a syringe to squirt fresh ink in through the hole you have drilled. You can also get messy here as you sometimes get bubbles blowing back and bursting, putting a nice layer of ink speckles on whatever is nearby - often your spectacles!
When you have got enough ink into the reservoir, you have to block up the hole you drilled. Some ink kits come with rubber bungs to put in the hole - but beware - they rarely fit properly and they let air into the chamber. This has the unfortunate side effect of letting all your fresh ink run out of the bottom of the cartridge and all over the inside of your printer. After several instances like that I threw the bungs away and used a blob of blu-tac which I double sealed in place with tape.
The next trick is to remove whatever you used to block up the big hole on the bottom and try and get the cartridge back into the printer without making a mess. If you succeed you will have saved a couple of pounds or so.
Unfortunately, as I found, the saving is short lived as the hassle is too great.
Anyway (if I'e not put you off) good luck
Dec 21, 2009 | Canon BubbleJet i560 InkJet Printer
Black wont print. Changed to new cartridge, nothing
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Office Equipment & Supplies
Main black print(BCI-3eBK)seems clogged and nozzle check shows only partial pattern. The cartridge seemed to be stuck to the print head. This happened before about two months ago. My technician cleaned it....
Sounds like you need a new printhead, and the only thing you need for cleaning is a damp cloth. All the Canon inks are water soluable. The printheads don't clean very well and don't last long if you do clean them.
Nov 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Ink Tank not showing up
That's a BCI-3eBK cartridge. Most Canon inkjet problems can be resolved by replacing the print head. eBay is the best place to find a replacement.
Nov 10, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
619 people viewed this question
old marine
old marine
