Question about Premiere Ranges P36S338BP Gas Kitchen Range
I put a board aganst the oven door and later tried to open door. when I did the door lifted and came off. Looks like it sits in two groves but cannot get it in far enough to match them up.
  • jay barfels May 27, 2011
    My range has a diffrent hinge system, there is not any hinge locks. My hinges are ok just cannot reinstall the door. Premire range P36S338BP gas. jay
    Brigadier General:
  • 4,736 Answers
The door sits over top of the spring hinges, in the grooves you mentioned. You may need a flat blade screw driver to line the top 'L' portion of the hinge into the slots/grooves on the left and right, on the inside of the door's base. The door should be almost in an upright position. to slide the door over the hinges. Once you have the door in place, slide it down over each hinge at the same time, keeping the door level from left to right. Once the top of the hinged 'L" is in place, slide the door down over the hinge until you hear or feel a click. The door is now properly in place.
Hope this helped you. Please let me know.
Posted on May 27, 2011
  • Rich Landrum May 28, 2011
    I'm very familiar with that model range, I have one. I understand the hinges are alright. I was trying to explain how the hinges work and how you need to slide the door down over them. The door is made to slide of, when necessary.
  • 4,323 Answers
Hi
Please check this video:
Hope this helps...please post back for further assistance.
Daniel
Posted on May 26, 2011
  • Daniel Scott
    Daniel Scott May 27, 2011
    Alright...check this one:
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
How to remove door hinge technica oven t948 please
This should be fairly easy. It does depend what model of hinge you have. On the bottom of the hinge there is an arm with a saddle lock pin - this pulls up to give space to lift the fitting off the oven frame - lift these on both hinges. On the face of the hinge where it sits on the door there should be a round screw - with the door fully open using a flat blade screwdriver turn this 45 degrees clockwise - this locks the top bar that goes to the frame of the oven.
Hold the door and with a bit of wiggling the whole door should lift off. The hinges are now easily removed by disassembling the door. Replace both hinges with new and reverse the process to replace. You do not need to remove or disassemble any part of the actual oven.
May 30, 2014 | Ovens
Oven door won't close all the way
I have had that trouble a couple of times. This might work. The door is usually attached to the body by two hinges with arms. You can lift the door off those arms and hinges by opening the door a few inches and lifting the whole door up in the air. Try this GENTLY. If the door acts like it will come off the body, it might be misaligned. Try lifting the door, and putting it back a few times, sort of gently twisting it from side to side. Really be gentle. This has worked for me several times. Be blessed.
May 12, 2013 | Ovens
Where do I put the siccor jack to life the car so I can change the front wheel?
In the grove in the middle of your framenotch go's into notch in jack good luck to ya.
Mar 30, 2011 | 2002 Suzuki Vitara
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Oct 24, 2009 | Ovens
Oven with an attitude
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Feb 27, 2009 | Baxter Ovens
I have a frigidaire oven model# FEF366DCB, the oven door does not close completely, it appears the the door is a little low so that seal does not sit in the grove can this be adjusted or do i have to buy...
THEY NEVER SIT REAL TIGHT,BUT SOME CAN.TAKE A TEMPERATURE (SAY 250)AND SEE IF IT HOLDS.THE IDEA IS TO SEE IF YOUR LOSING HEAT OR JUST BAKE SOMETHING TO SEE IF IT IS UNDERCOOKED.YOU CAN CHANGE THE HINGE IF YOU WANT TO BUT I DONT THINK IT IS NEEDED.
Jun 06, 2008 | Frigidaire Kitchen Ranges
Door
your oven needs two new hinges on the affected door. I have seen this problem many times, the internal stops on the door bend over time and cause the door to not close all the way. They are fairly easy to replace, you just have to split the door open to repalce em. Hope this helps!
Dec 19, 2006 | Thermador SEC301BPSS Electric Single Oven
Premiere Ranges P36S338BP Gas Kitchen Range Logo
67 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
