Question about Gaggia Classic Espresso Machine
One of the filter baskets is constipated, the other one works well. Somehow it must have been polluted with coffee of chalk on the inside. How can you clean this?
    President:
  • 1,618 Answers
Put it on the stove, the fire will burn out the coffee before the metal burns.
Posted on Jun 02, 2011
Overflow in basket
Steven, I think it`s not the filter or the coffee just that more water is flowing into the basket then it can process. I would try lesser quantity of water first to see if it overflows. Try first with filter only and then with coffee. And before you do all that, your machine should be under warranty and may be returnable to the store. Do that and save the trouble of fixing it.
Mar 22, 2014 | Black & Decker CM1050B
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    Brewed coffee mess
    You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
    Aug 13, 2009 | Bunn 10 Cup Home Coffee Brewer
    The coffee maker prematurely turns off at
    Hello 1pro8vo2,
    This is a common problem with Cuisinarts and is fixable.
    I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
    Jul 11, 2009 | Cuisinart Coffee Makers & Espresso...
    Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
    Hello tfsmithcambr,
    You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
    Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
    Bunn coffee pot blows water out top of basket
    Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
    Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
    Missing the black filter basket to my coffee maker
    I would suggest calling Kitchenaid Customer Service. They may be able to send this part out at no charge or low cost to you as a replacement.
    Their toll-free telephone number is 1-800-541-6390.
    Mar 30, 2009 | KitchenAid PRO LINE KPCM100 Coffee Maker
    Making Coffee
    Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
    I hope this fixes ya up!
    Please rate my response!
    THANK YOU!
    Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
    COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
    Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
    Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
    Grounds splash from basket into carafe
    My brother has a Bunn that does the same. I think the coffee filters he is using are too short. If you think this might be the problem too, try an internet search for Bunn coffee filters. Hope this helps!
    Jun 19, 2007 | Bunn GR10 Coffee Maker
    Gaggia Classic Espresso Machine Logo
    51 people viewed this question
    Top Gaggia Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
