Question about Briggs & Stratton Garden
Will start in choke mode only. Then quickly dies. Replaced vacuum fuel pump, but this did not correct the problem. Replaced fuel filter, but this did not correct the problem. Replaced spark plug, but this did not correct the problem. Am about to pull off the carburator and clean it, but thought I would ask your advice first.
    Novelist:
  • 184 Answers
Some had an adjustable main jet. try turning it in and back out again. If it is a fixed jet, your rebuild is on the right track. Replace the crankcase breather to air filter hose while you are at it as these rot pretty fast.
Posted on May 26, 2011
Briggs&stratton 19.5hp - starts for few seconds then dies
Could some debris in the tank, fuel filter may need changed, If it has a fuel pump it could be weak or worn out, Check for fuel and vacuum line cracks, This would cause it to suck air instead of fuel.
Feb 03, 2018 | Garden
Have husqvarna 1542. When pushing in the choke it dies. Have replaced battery, solenoid, fuel filter, cleaned carburator. Will not run when pushing in choke. Need assistance
this 15 hp Kawasaki engine needs lots of gas to run , and taking the choke off and engine speed falters is a sure sign that you have a fuel delivery problem (choke richens fuel mix)
id start with the simple things and move to the more difficult ones
(1) fuel tank - valve on , fuel in tank, hose not broke or crimped
(2) fuel filter replace or clean out fuel filter look for cracks in fuel lines as well
(3) fuel pump - if im not wrong these engines use a vaccume operated fuel pump , these are critical to have good hose for vac supply on (correct type as well)
(4) good working carb - this should have a factory minuki carb , these work very well and don't require a lot of maintence as others might , but they do get stopped up with fouled gas and they do eventually wear out as well requiring rebuilding or replacement , also lots of folks forget that the other part of a working carb is the air , air filters need to be clean enough for sunlite to penetrate thru them ,if you cant see lite thru then air cant get thru either
Jul 19, 2015 | Husqvarna Garden
Husqvarna 141 starts with choke and then cuts out
If the chainsaw has been used recently i would say It sounds like the screen filter inside the carburetor is dirty item # 507432582 or the metering diaphragm is dried out item # 530035165. Also check that the fuel lines are in good shape. If that doesn't solve your problem you should do a pressure and vacuum test to check the seals and gaskets.
Feb 01, 2014 | Husqvarna Garden
My truck wont start, changed the starter and battery?
Check the fuel filter. A completely plugged fuel filter will stop your engine cold by choking off the flow of fuel to the carburetor or injectors. The engine may not start, or it may start, then stall and die. Next most common problem is the fuel pump failing. Most modern electric fuel pumps can be heard when you turn the key on. If you don't hear the pump running and your car will not start, it could be your fuel pump. The first thing a mechanic will check is the relay which sends power to the pump. If this is operating correctly then the pump will have to be replaced.
Jan 25, 2011 | 1995 Nissan Pickup
Hello, After my 1987 F-250, 7.5 L V-8, 4BBL sits for more than 12 hours I have to pump the accelerator anywhere from 20 to 50 times to get it to start. Once it starts it runs fine. I have replaced every...
That would be a Holley, probably model 4160 carb on it. You need to do a little detective work on this. You either need to adjust the choke or find out where the fuel is going after 12 hours.
First, when the engine is running check the Intake and Carburetor gaskets for vacuum leaks. Also spray by the Vacuum reserve canister (Like a coffee can) with either Choke cleaner or a water mist. Either way the RPM will change if you have a Vacuum leak. Fix the vacuum leak if you find one. The engine needs Vacuum to draw in the fuel for a cold start. There are vacuum ports with gaskets (Hidden until disassembled) where the Choke housing attaches to the main block of the Carburetor. A leak here will mess up the tiny piston inside the Choke. (Its under the Black cover and operates the stepup for cold starts).
The black choke dial should be set for 2 marks rich. You should not need excess force on the choke flap to unload it. The choke flap should maintain an opening about 2 credit cards thick measured between flap and carb housing. To get this space you bend the rod pushing the choke flap. This should help the choke work better.
If this does not help, on the next 12 hour interval check for fuel by taking off the strainer on the Carb inlet and remove the line from the carb to the pump. If the fuel line is dry you are losing the Prime to the pump. You must have either a bad pump or a hole in the fuel line from the tank.
Would like to know what you found. The Power pump inside the front bowl of your Holley has a number and you can go to a Holley website to see if it is correct for your truck. The fuel inside the front bowl of your Holley should be enough start the truck. Even if the bowl went dry overnight, the fuel pump would replenish the supply well before 20 to 50 pumps.
Nov 04, 2010 | 1987 Ford F 250
1992 Honda CB 750 Nighthawk will not idle without choke
Hi, Emeraldcp and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
Honda Nighthawk CB 750 1991 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 26, 2010 | 1992 Honda CB 750 Nighthawk
Does not appear to get fuel properly/changed fuel pump
fuel filter ? air leak in carb. gasket , vacuum leak , dirty carb or choke stuck closed
Apr 28, 2009 | 2004 Ford F150
Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Nov 23, 2008 | Garden
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
