Question about IBM ThinkPad T20 2647 Notebook
Ibm t43 does notkeep accurate time or date - IBM ThinkPad T20 2647 Notebook
5 Suggested Answers
  • 274 Answers
SOURCE: how to remove IBM t43 start up password
If you know the password, enter the BIOs. At start up you should see that option briefly displayed. It will prompt you for the password. Once its entered, you can do what ever you'd like. There are "three different password groups" on your machine. POP, HDP, and SVP (Power on, Hrd drive, Supervisor). If you don't know "either the HDP or especially the POP", there is nothing you can do except buy an new MB or HD. There is not short cuts. Hopefully you have the passwords and you'll be OK.
Posted on Aug 26, 2007
hacker8499
  • 74 Answers
SOURCE: IBM t43 laptop wont power up
did you try to check if the power supply is working properly coz if no lights at all it means no power is coming.
Posted on Sep 16, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
  • 4090 Answers
SOURCE: always reset time and date IBM T43 think pad
the internal battery is damaged and not recharging you may need tor consult a tech to have it opened and replaced as most are inside under keyboard
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Error 0271
Is your date and time correct? You may need a new CMOS/RTC battery? Does the Laptop loose time/date/year, when you plug back in, after being unplugged without battery installed?
May 12, 2013 | IBM ThinkPad T43 Notebook
IBM thinkpad t43 how do I access safe mode when I am the BIOS
Exit the BIOS and boot up the T43 and then press F8 function key several times. You can then select Safe Mode from the list of boot options.
Dec 05, 2011 | IBM Computers & Internet
Audio driver ibm
Do a google search for: ibm thinkpad t43 drivers and it should bring up links to the ibm support/download site. Just make sure you know what OS you are running when you find the driver you are looking for. I had to do this for my t43 not too long ago after a hard drive replacement.
Dec 04, 2011 | IBM ThinkPad T43 Notebook
<li><a
IBM Thinkpad X40 Battery cost EUR 79.99
Dec 23, 2010 | IBM ThinkPad T43 Notebook
Always reset time and date IBM T43 think pad
May 07, 2010 | IBM Thinkpad T43/p Notebook
I need sound driver for IBM laptop T43
Use the link below to download a driver of your thinkpad T43. Click the file link 1ya210ww.exe.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58599
Feb 07, 2010 | IBM ThinkPad T43 Notebook
Ibm thinkpad t43 windows xp it has ad-block from
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
Jan 21, 2010 | IBM ThinkPad T43 Notebook
Date and time never save if I restart the computer.
Yes, the small battery on the motherboard is dead. Turn it over and start unscrewing all the screws, you'll find it.
Oct 27, 2009 | IBM ThinkPad T43 Notebook
Time or Clock changes
check with antivirus software. same problem came again battery only problem!
Jul 01, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T20 2647 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
