I have a Shontek radio controlled clock. It ran fine for a couple of years, then the battery died. I install a new "Durcell" battery and it went through the motions of setting itself but was a few minutes wrong. I have tried it a couple of times and now it is 20 minutes wrong. Then I tried to set it manually and that worked for a few minutes then the clock tried to set itself again and is now about twent minutes wrong. I have another radio controlled clock so I know that the time is wrong. Hope you can help. CD
    Sergeant:
    Novelist:
  • 159 Answers
Your radio should have come with a receiver of some sort for the radio signals to set itself. I had this same issue with my clock when the battery in the receiver died ... try replacing this too. It took me forever to figure out what it was because I had forgotten that it had its own radio receiver ... then once I remembered it existed, I had to find it, but replacing the battery fixed the problem. Hope that helps :-)
Posted on May 26, 2011
Had to change the batteries in the Atomix clock and now the
Hello
What is the Brand name and Model number of your Atomic clock?
Jan 04, 2012 | Audio Players & Recorders
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Van dormant for three years. installed new battery,started and ran good for two hours, died, fuel guage malfunctioned(still),radio stopped working(still),i.e.,no 12 volts to orange wire. installed new...
The fuel gauge is probably fine, its the sending unit that is probably bad. As far as the radio I would run another power wire from 1 of the accessory ports on the fuse box. Just make sure you test the port so it goes on and off with your ignition. Just test the port with a light tester. Please rate answer!! Thank you
Sep 14, 2010 | Chevrolet Astro Cars & Trucks
My Emerson CKA1000 clock radio worked great for years, but now it eats the battery back up, battery will go dead in a month or so and if I set the alarm for radio it will show the 20 ne message when the...
Sounds like the main power supply may have gone bad and you are strictly running off the battery. This is why it works fine for a while when you install a new battery, that is until that battery drains and gets too low. The radio won't play because it is preserving battery life. I bet you could unplug it from the wall and would get the same results. You essentially have a battery powered clock right now. To test this theory simply remove the battery, plug the clock up and see if it comes on. My guess is it will only work with the battery installed.
Jul 23, 2010 | Emerson CKA1000 Clock Radio
Shontek clock movement from Sam's club not keeping time
Were you able to repair your clock ? I have the same 24" clock from Sam's Club and have given up on finding the Shontek DM2720 movement. Please let me know.
Jul 01, 2009 | Audio Players & Recorders
My battery died last week i got a new installed now my radio and cd and my clock not working i put new fuse in still not working
you need the owners manuel. there are some weird solutions th these problems. they vary with the accesories. try calling the service dept. at the dealer. they can be really helpful in most cases.
May 23, 2009 | 2004 Pontiac Grand Am
Radio controlled clock not working
Pretty simple: Press reset. Clock should reset within 10 minutes.
Manually set by pressing Set and holding for 5 seconds. The hands will turn. Release when they get to the correct time.
Mine quit working after a year and seems to be dead. The movement won't do anything now with a new battery.
May 10, 2009 | Audio Players & Recorders
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
1,087 people viewed this question
 Grubhead
Grubhead
