Question about Nortel T7316E 2-Line Corded Phone
I have a Nortel phone system with a T7316E phone with 2 lines instances, I want to add a 2nd line with a different phone number. how do I do this? Thank you Frank
  • 2 more comments
  • frank Sanchez May 31, 2011
    Kenneth:
    I am using a T1 going through a Phone switch I need to know how to program the Nortel switch to show the 2nd line on the phone set.
    thanks
    Frank
    I know I can do it that way, how ever I did not want to use a 2nd port, I think the switch can be programed to have a 2nd phone number assigned to the phone with out hardwiring a 2nd line. I,m going to want this line on 3 phones
    thanks
    Frank
    I have a Nortel phone switch on one phone I need to program the switch so this phone has 2 phone lines with different numbers. how do I program the switch?
    thank you
    Frank
  • frank Sanchez Jun 01, 2011
    I have a phone switch I need to go in and program the switch. i do not want to call anyone I want to program the switch to feed the 2 lines to one port and display them on one phone set. that is what I am looking for.
    thanks
    frank
  • Nortel Master
  • 2,460 Answers
A "T" phone connects to a Nortel system cabinet, a CICS, MICS, or BCM unit. The lines appear on a connector that is punched down on a frame. If you don't have installation and programming instructions for the system, you probably need to call a professional installer.
Carl
Posted on Jun 02, 2011
  • 32,281 Answers
You need to contact your phone provider and arrange to have a 2nd phone land line install to your premises and have the outlet installed next to your Nortel. The provider will allocate a new phone number for this 2nd phone line.
Posted on Jun 01, 2011
  • 416 Answers
When you activate the second line with your service provider tell them that you need both lines to come through the same jack. Then simply connect a line to each of the connections under the device and you are good to go. Call ID and other features are all setup automatically
Posted on May 31, 2011
  • Remote Computer Rescue
    have you service provider run your second line through the same jack and simply place one jack in each of the "Line" receptors on the bottom of the unit. Simply select the line you want to call from before you pick up the handset to identify the intended outbound number. All incoming calls will still come in as though there where two phones.
I need the administrator password
On Nortel T7316E admin password should be 23646 - 2=A 3=D 6=M 4=I 6=N
To be sure, check out the user manual which you can get here: Nortel t7316e user manual
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
How to move extension numbers from office to office using nortel t7316e
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
Aug 10, 2010 | Nortel T7316E 2-Line Corded Phone
How do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Mar 05, 2010 | Nortel T7316E 2-Line Corded Phone
Online cheat sheet for the feature buttons on the Nortel T7316E. I work for the school system and our people keep loosing their cheat sheets. I'd like to refer them to a link so they can reprint anytime.
Here's the cheat sheet you were looking for. Here at IdacomUSA we provide User Guides and System Manuals for every system and phone that we repair. We also repair the Nortel T7316E for $75, which will transform your old phone into one that looks and works like it was purchased yesterday.
As for the link for your cheat sheet, here it is.
Nortel ICS Telephone Feature Card
Jun 22, 2009 | Nortel T7316E 2-Line Corded Phone
How to add a second lint to Nortel Phone System???
So what, exactly, is your question? Physically, you order a second line in a "hunt" group, and plug or wire it into the system cabinet. By default, a Nortel system has 2 lines already programmed to the sets, but you will probably need to activate the second line appearance in programming.
Carl
May 20, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E acts like M7310
Feature *81 will move line buttons.
May 04, 2009 | Nortel T7316E 2-Line Corded Phone
Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Dec 17, 2008 | Nortel T7316E 2-Line Corded Phone
Programing my nortel t7316e charcoal to access whole phone lines
If you are fmailiar with the programming of the system, you must set the lines (3-8) to appear and ring on the extensions.
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
DO NOT DO THIS UNLESS YOU ARE FAMILIAR WITH PROGRAMMING.....
Nov 11, 2008 | NorStar T7316E Corded Phone
Nortel nt8b telephone
Get on the line and dial 1800 444-4444 and when it answers it will tell you the number then hang up.
Nov 07, 2008 | Nortel T7316E 2-Line Corded Phone
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
51 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
