Question about Refrigerators
Frigidaire 11.3 Cubic foot model FFU1152DW4 fan and compressor running but not cooling
5 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Not cool at all!
If the compressor is running you should be cooling unless there is a major loss of refrigerant. What we do for these complaints is to first let the refer run for a few hours then pull the interior rear panel off the freezer section back wall and check the frost pattern on the coils. It should be a nice white frost pattern all the way across the coils (no bare alum. showing and no mass of ice either). If you don't have that pattern then there is a sealed system issue. If you have a massive block of ice all over the coils then you have a defrost cycle issue (not getting proper air circ. due to the block-o-ice thing). Let us know what you find... oh, you can sometimes find the leak by looking for oily residue from the compressor lubricating oil (it leaks out where the gas does also).
Posted on Jan 17, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
peyton32034
  • 410 Answers
SOURCE: freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Posted on Jan 28, 2009
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
FFU17FC4CW0 FRIGIDAIRE FREEZER Manual
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
Not cooling the fan is working. there is whirring noise as if the compressor wants to start but it does not. this noise keeps on repeating
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Frigidaire Side by Side 26.0 Cubic Foot...
11 YEAR OLD SIDE BY SIDE SUDDENLY STOPPED COOLING BUT THE FAN RUNS AND DOSE NOT SHUT OFF.
heatman101
Jun 08, 2011 | Whirlpool GS6SHAXLT 25.5 Cubic Foot Side...
Compressor builds up air, but when i go to use tools looses pressure to point that its not usable.
how big is the compressor? if its only say 3 cubic foot a minuet that is at free air pressure not at say 8 bar,,,at 8 bar it would only be 0.375 cubic foot,, check to see how much air in cubic feet per minuet and at what pressure your tools need to work on
if they say 5 cubic feet at 8 bar and the compressor is only 3 cubic feet at 8 bar the tool will only run for a very short time before the compressor air tank has run out of air and the compressor cant keep up with the demand from the tool
the bigger the compressor and the bigger the air tank the better some times,,,for a hammer tool you need 8 cubic foot at 10 bar
thats a big compressor!! or a small one for only a short burst of time,,, in short,,,all ways go for a big un? compressor that is!!
i hope this has helped you out
Aug 26, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My frigidaire is not getting cold. Is there a way to troubleshoot to detemine if it's the compressor gone bad?
Good day,
Here is a basic checklist any qualified tech would use to isolate why a refrigerator won't cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer or electronic defrost control.
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see, there are multiple reasons a refrigerator won't cool, or cool properly.
To zero in on the compressor might take you away from the true non-cooling reason.
However. The compressor might have a defective relay or thermal overload that would prevent it from starting or running. Theses items can be removed from the compressor and taken to any appliance parts houses. Most all would be glad to test them for you.
As well, the compressor could have a bad valve internally that would prevent the compressor from pumping refrigerant, or there could be a restriction in the refrigeration lines preventing the refrigerant from circulating properly, or the windings in the compressor could be burned out or shorted, or lastly, the system could have developed a leak. All of the above compressor related issues, except for the first one could only be checked by a qualified tech.
I would treat the problem as a whole with the compressor being one of the potential issues.
Not to throw a monkey wrench into this but a refrigerator is like a car.
9 out of 10 times the problem and solution are obvious. It's that last 10% that take all the training and experience.
May 19, 2010 | Frigidaire FRS26H5AS Side by Side...
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
12. Excessively dirty condensor
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
