Question about Dyson Ball DC24 Bagless Upright Vacuum
The front roller is not working i tried to open the whole assembly of the bottom panel but the moter is not responding to any of the buttons assistance required urgent.
  • Official Brand Answer
  • 2,572 Answers
You should be able to resolve this issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1502&product=DC24-ALLFLOORS
If you're still having problems, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run though some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 08, 2011
Wont re-assemble
Assuming you did not remove the brush roller to clean it and consequently did not reseat it, I am guessing that the bottom plate is not reinstalling as it should. On some uprights, the bottom plate hooks in at the front and is latched in place with clamps. This can be difficult if there is interference with other parts. Give me some more detail on what works and what doesn't
Jan 23, 2013 | Dyson DC14 All floors Bagless Upright...
I need instructions on how to change the belt on my Hoover Model U4264-930 vaccum.
Tool Needed, flat head screwdriver (larger one works a little better). Serious Safety Precaution: Make sure unit is unplugged. Preliminary: Check: that nothing is caught like threads etc, preventing roller brush from turning. I've had this model vacuum 10 years and have pulled threads out countless times. However it still has the original belt on it. To change belt: 1.) There is a plastic plate underneath roller, towards front.. Pry the 3 tabs at front, the plate hinges downward slightly (to clear the front tabs). Next, there are 2 little clips at bottom of plate. Insert screw driver at each of these clips to fully release the plate the rest of the way. (Or it may even come off without having to pry back on these. The plastic clips need pushed towards front, to clear the ridge that catches towards the back). Pry one, then the other, clip forward, while gently pulling the plate the rest of the way out. (Gentle prying will assure it will snap back together OK, so you still get a good seal.) You now should see the whole roller brush. 2.) Remove the shell/motor cover: To do this, a.) pull off the rug height adjuster lever, and take not where you put it so you won't loose it. b.) push foot release down and keep vacuum bag in the vacuuming/hinged/operating position (not the upright/locked position), and position cleaner on it's side, or upside down. c. Pry around the bottom edge, starting at right corner, then go around, prying in about 4 different places. Shell/motor cover will now easily pull off (upward and out towards front), exposing motor shaft and light bulb. 3.) remove belt from motor shaft. 4. slide roller and old belt out the bottom. 5.) remove old and place new belt on roller 6.) slide roller back into place. 7.) wrap other end of belt on motor shaft. 8.) shell cover, rug height adjuster knob, and bottom plate snap back into place. check that roller turns without much effort. 9.) It now should be ready to plug in and vacuum.
Aug 21, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
Runs but doesn't vacuum/****. Sidebrush works fine. Cleaned the roller brushes, and that seemed to confuse the robot and now it keeps going backward a few inches, turning, and then starts going backward...
sounds like a sensor problem. pull and clean the front black/white caster assembly and the revealed movement sensor and the 4 cliff sensors along the bottom of the front. Make sure the front caster wheel turns freely. You may have to remove the roller from the caster assemply and push the axle out and clean it.
Oct 08, 2009 | iRobot Roomba 560 Robotic Vacuum
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
Apr 14, 2009 | Electrolux Vacuums
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
Dyson DC07 Filter Release Catch removal
yes sorry i know what mean you need to remove the motor casing to reduce the risk of breaking any parts. Lay dyson on the front and remove the bottom plate and roller bar. Now you need to remove the belt from the motor pin lay on left side look t the round clip located next to the wheel which is holding the whole floor atachment to the chasse. Remove the clip with a flat ended screwdriver then flip to opposite side and repeat the same. The floor atachment should be moved to the down position as far as possible. now you can remove the the bottom attechment starting from the opposite side to the belt now undo the four screws on the bottom of the chassis and remove the screws under the other filter on top of the moter now remove the top cover now the piece in the way should move out.
Nov 11, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction in floor attachment *& brush not turning
Lay the machine on the floor with the front side down. Undo the 3 large plastic screws with a coin of some sort, then remove bottom panel. On the back of carrage where the roller bar sits their should be a clear plastic tube check this tube is free of dirt. Check around inside the carrage for hair string etc. Check belt for breaks and swelling in the rubber pull ont roller bar and check the end caps on the roller can spin freely. If not pull off the end caps these will be very tight and wash out all dirt and fluff, dry thourley and lubricate centre pin and end caps inside the roller with baby oil or wd-40. replace roller bar and belt, turn roller bar twice slowly to centralise the belt, replace bottom panel making sure that the clips on front are sitting in their holes. fastern the plastic screws and leave two hours before usage
Oct 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
155 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
