Question about Garden
My Cub Cadet RZT 50 PTO disengages occassionally. I noticed that although the clutch stays firm the shaft seems to be out of balence and wobbles. The left steering arm if shaken gets the PTO working again. Should I be concerned about the wobble or is that normal? Is there a way to bipass the reverse safety switch and is that advisable?
3 Suggested Answers
  • 64 Answers
SOURCE: PTO will not engage on
see if the switch is getting power to it and if it is see if the clutch is getting power. it needs 12 volts in order to engage.
Posted on Feb 24, 2011
SOURCE: pto blows the fuse everytime i engage it on my rzt
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Posted on Sep 09, 2011
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
The mower deck on our Cub Cadet RZT 50 mower stopped working while mowing. We have cycled the PTO switch several times with no change. The belt is in place and the mower blades rotate freely by hand. The...
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
May 30, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
