Symptoms= Oven light ok, thermostat light ok, oven not heating at all or to a low heat. May also have tripped the circuit breaker on the switchboard
Probably the element
Switch off power to the oven at switchboard
Open the oven door just a little and pull the door up to remove it.
Lift the panel at the oven back wall over the fan.
See the coiled element, you may already see a defect in the surface of the element.
Remove the screw at the base of the coil
With a small sharp screwdriver flip out the clip on each side of the element at the top
Feed the element out of the holes
Note that the green wire is attached to the frame of the element and the red wire to the core of the element.
The other side of the element may have two white wires
Disconnect all these wires, maybe using a pliers.
You can check this element with a simply multimeter, buy a new element and refit opposite to removal
