Question about GE Heating & Cooling
My GE room air condition model no. AGR05LJG1 fan speed switch runs on high only. no low speed.
  • petegrubbs May 27, 2011
    Removing the fan from the A/C unit?
    Brigadier General:
  • 4,044 Answers
The fan needs replaced. Sometimes these have a control capacitor that can be replaced to fix the problem but in most cases I have had to replace the fan motor.
Posted on May 26, 2011
  • James Young May 27, 2011
    Yes, you can open that unit up and remove the old fan and replace it if your careful not to break any of the copper lines or damage the coil. The fan that moves air through the unit to cool has nothing to do with anything but moving air. It makes no difference to the cool the AC puts out other than air flow. The compressor and coil control how cold the air actually is. If the coils are clogged they will reduce air flow and reduce cooling. You stated your problem was the fan not going to low speed and that is a fan issue in most cases.
Why is the fan only running on low speed?
Hi David. when the air conditioning is energised by the thermostat it should automaticly bump up to high fan speed, if it has been running for a while it ciould be freezing up the evaporator and causing a restricted air flow to come out. you may need to shut the cooling mode off and just leave the fan running for a few hours. hope this helps
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
My GE 50 pt humidifier works great - except it will not let me set the fan speed to low or medium - it runs on high all the time. I am SUPPOSED to be able to set fan to low.... HELP IT"S TOO LOUD ON...
It sounds to me like you have a defective switch. I would recommend that you contact a G.E. dealer with the model and serial number and describe your problem.I can't find the right file right now but I believe thatthis switch is about twenty dollars.Thank you.
May 14, 2011 | GE AHG40LA Dehumidifier
Air conditioning / heating system fan works on
Fan resister circute/switch needs to be replaced. Not expensive. Buy from dealer.
Aug 02, 2010 | 1993 Nissan Pathfinder
My air condition unite outside keeps going on and off.it works for about 30 seconds and then shuts off, to restart in about anothre 30seconds and this goes on and on. aooreciate any suggestion.
Is both the fan and compressor cycling?
If they are it sounds like the unit is cycling on a high or low pressure switch.
If it's cycling on the low pressure switch, it could be dirty indoor coil or filter, blower capacitor, blower not running or not running at the proper speed or you could be low on refrigerant.
If it's cycling on the high pressure switch then it could be a dirty condenser coil, outdoor fan capacitor or fan not running or not running at the proper speed or to much refrigerant (overcharged).
Unless you you know how to check these out, then you probably need to have it checked out by a HVAC service technician.
Jun 16, 2010 | Carrier 38CKC036 Air Conditioner
A/C FAN ONLY OPERATES IN LOW SPEED
It is either the switch,or the motor ,the motor is designed to have the speeds in it it self,but check the voltage on high,from the switch to the motor,if there is voltage,the motor is the problem.
Jun 06, 2010 | Heating & Cooling
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Water spill
1) Press the POWER SWITCH key (Fig. G) to
switch the unit on.
2) Press the MODE key (Fig. H) until the DRY
indicator light illuminates on the control panel
(Fig. I). Each depression of the MODE key will
advance to a different mode setting (Cool -
Dehumidify - Fan - Auto )
3) If the room temperature is > 25°C (77°F), fan
speed can be adjusted. Press the FAN key (Fig.
J) to select the desired FAN SPEED setting. Your
selection will appear on the control panel. Each
depression of the fan key will advance to a
different fan speed (High - Med. - Low )
as shown in Fig. K. Otherwise fan speed is fixed
to low.
Note: The warm air exchange hoses must vent
inside the room when using Dehumidify mode.
Jun 01, 2010 | Danby DPAC7099 Air Conditioner
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
422 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
