Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
The oilcap on the Yardmachine mower is really unusual. It is a small yellow cap that has 2 raised knobs/bumps on it, and no other discernable gripping surface for turning. How do I take this cap off to put oil in?
    Novelist:
    Champion:
  • 222 Answers
Sounds like the good old fashioned Briggs engine oil cap. They're designed that way so that if you screw it on too tight (or the crud stops it from turning freely) you can simply put a large screwdriver between the two knobs and use it as a lever to get the cap unstuck. Hope this helps. Good luck.
James
Posted on May 27, 2011
How do i get bump knob off it turns like its stripped be turning on it for an hour im tired
the bump knob is left hand thread so make sure that your are turning it in the right direction ( clockwise to undo it)
if you have been doing that then after 10 minute I would have taken it to a mower shop
May 13, 2016 | Homelite Garden
My 1.4ecotec astra is leaking oil out of oilcap when its closed what cud the cause be
Possibly the seal/gasket on the oil cap is defective. You can try replacing the cap to see if it corrects the problem. You may also have excessive internal pressure within the motor due to an improper functioning PCV system. Inspect/replace the PCV and related hoses for proper operation
Jan 20, 2016 | Cars & Trucks
How to remove oilcap from a murray 4.5 hp q select20 lawn mower
If it's a Briggs and stratton engine the oil cap is at the back. These usually come out using a large screwdriver.
Jun 25, 2013 | Garden
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
I have a 2002 YardMachine, 660 Model, 15.5 HP, 42" Cut. Two Issues. 1) After changing of PTO Cutting Blade Belt, mower lost all power to transmission. No GO F or R. Before belt change, mower would loose...
without looking at the belts i will tell you that the wheels on most mowers only come in a few sizes and are made by just one or two companies. so find a mower or small engine repair shop in the phone book and go get some new wheels and bearings from them. makes it easy if you take an old one with you. while you are there run the belt issue past them and maybe they can give you some guidance.
Oct 18, 2010 | Yard Machines 42" Tractor Mower Blade Kit ...
Where is the oil drain plug?
Do you see a small plastic yellow cap on the side of the engine below the oil dipstick? If so you pop the cap off and use a small plastic tube to drain oil away from frame and slip over the place where the cap came from and push in and turn to the left( I think). When the oil quits draining push in and turn back the opposite way then replace the yellow cap.
Apr 27, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
22" yardmachine starts and stops
loosen the bolt on the bottom of the carburetor up and let the water out and then re tighten and try it
Jul 22, 2009 | Mtd 22" Yard Machine Push Mower
Solution for ''i cant get the spark plug cap off my yardmachine does anyone know how too''
take a pair of pliers and grasp the cap at the end of the spark plug. work the cap clockwise and counterclockwise back and forth while pulling away from the engine. just a little bit of corrosion will lock them down
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
102 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
