Question about Sony SDX 420C (SDX-420C) AIT Tape Drive
It was working fine and I let it sit for about a year. When I hooked it back up, the three lights in the front just keep flashing and if you look in to the slot, there''s a piece of flat metal that seems to be blocking putting a tape in
  • Ray Rogers May 26, 2011
    To be more specific....I just realized that the metal piece is part of the apparatus. The computer is not recognizing the tape back up machine and the lights on the front continuously flash only after I connect the firewire to the computer.
    President:
  • 3,278 Answers
Hello.
First, power off the system connected to the drive.
To remove metal in a drive, I've used 2 tools: my pinky finger and a plastic knife.
If the slot is too small for a pinky finger to dislodge and remove the metal, try a plastic (not metal) knife.
Be careful not to scratch the drive heads.
Hope this helps.
Posted on May 26, 2011
  • NinaE May 26, 2011
    Hello, again.
    If you wish to take the drive partially apart, please take care or the drive could become damaged.
    Remove the drive from the chassis or enclosure to allow access to the bottom and right side of the drive.
    Remove the drive's top cover.
    Locate the small opening in the bottom of the drive and insert the tip of a precision screwdriver so that the Threading Motor shaft can be rotated.
    Rotate the motor shaft counterclockwise to bring the threading mechanism back to the initial position. Stop rotating the motor shaft immediately, Otherwise the gear of the drive can be damaged.
    See if you can remove the flat metal or see where the problem lies.
    It's possible that your drive is faulty and needs repair or replacement.
Major electrical problem? No previous warning.
We had this same problem after my brother hooked up jumper cables backwards.
We had to replace computer boaord under the driver side dash. I can't for the life of me remember the name of it. lol But someone who can hooked that up and get the codes can tell you if it needs to be replaced. I found mine on ebay....they are Hard to find!
Jul 29, 2012 | 2003 Ford Windstar
I have a 1978 yamaha xs750 special. The blinkers worked fine on the left, then I hooked up the right side blinkers and nothing. The front right worked well until I hooked up all blinkers, now front right...
I used to have a 76 XS500. Got lots of compliments with that bike.
The wattage of the bulbs is important on how the blinkers work. The rate they flash, and if they flash is dependant on the current being drawn from the lights. Thats why many times if you have one light out the remaining light may stay on solid or flash faster.
You could try removing one bulb on each side and see if the blinkers work. Then reinsert and remove the other remaining bulbs. If they work normally with one bulb in each side whether front or rear then I would suspect the flasher relay.
Say the fronts work when the rear are out and the rear don't work when the fronts are out then I would suspect either the bulbs or sockets or your solder connection or switch.
You may also look into an electronic flasher. They automaticaly adjust for variable loads to flash so they flash at a normal rate.
Aug 24, 2011 | Yamaha XS 650 SE Motorcycles
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Screen (f-28) and keep flashing
call for service this is a covered repair. you have something wrong with your motor or a loose connection somewhere. You say this is brand new if it is less than one year it should be 100 percent covered
Apr 23, 2009 | Kenmore Washing Machines
No power output from my vector 1000w inverter.
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
X BOX 360 ROCK BAND 2
if they're wireless you need to sync them with the xbox. theres a button on the drumset that is small and round with three smiley lines push that then push the one on the front of the xbox and it should stop flashing and one light will light up. good luck!
Dec 25, 2008 | Video Game Consoles & Games
Samsung DLP HLM437W won't turn on
my advice is that if the project is getting expensive kindly invest in a new tv. i am nt familiar with that set but you are having a micro processor problem replace it and your tv will work fine as it was before good luck.
Jul 18, 2008 | Samsung Televison & Video
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Sony SDX 420C (SDX-420C) AIT Tape Drive Logo
171 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
