Question about Vapor Professionals TR5 Pro Handheld Steam Cleaner
MY TR5 VAPOR CLEANER WAS WORKING YESTERDAY. TODAY I TRIED TO USE IT AND TOOK OVER TWO HOURS AND THE TEMPERATURE ONLY REACHED 180 DEGREES. MY FRIEND TELLS ME IS THE COIL. DO YOU THINK IT NEEDS CLEANING OR I NEED A NEW COIL ? CAN I PURCHASE A NEW COIL? THANKS FOR YOUR HELP. GRACE
Does this cleaner heat up the water for steam? It is called a steam cleaner, but I do not see anything about how to regulate the temperature of the water to make the steam and so no one gets burned.
Steam is steam is steam - it has a temperature of 212 degrees F and if you go any lower it is no longer steam - condenses back to water. Capiche? If you pressurize the steam you can then raise its temperature to a super heated condition. How do you think a pressure cooker works??????
Aug 26, 2017 | Vacuums
Reset button on hoover wind tunnel
Hi there! There is no reset button on the cleaner. The vacuum has a thermal protector sensor that will shut the vacuum off when the motor reaches a certain temperature. This is usually caused by a clog or filter that needs to be cleaned or replaced. Be sure to check the hoses for clogs and clean and replace any filters if needed. The vacuum will turn back on when it cools off, this can take up to an hour. Good luck!
Jul 10, 2014 | Hoover Ultra U6430-900 WindTunnel Bagged...
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Often when ironing, the iron{tefal aquaspeed 160] will spit dirty water on whatever I'm ironing.are you supposed to use botled water in iron?Aren't tefal irons made for tap water?Also how do you stop iron...
Try using CLR cleaner, if not just buy a new one, and keep the receipt for a return down the road, these iron's are reasonable nowadays.
Apr 25, 2011 | Vacuums
I cant use the hose
There will be a dial on top of the tank that you can rotate 180 degrees which will switch the unit from vacuum to hose.
To switch it back to vacuum, rotate the dial back 180 degrees.
May 20, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vapor Professionals TR5 Pro Handheld Steam Cleaner Logo
41 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
