Question about Cub Cadet Garden
My Cub Cadet self propelled lawn mower, with caster front wheels, doesn't self propel at first but maybe after about 15 minutes of mowing, the drive engages and will work for the rest of the session. The next time I use it, the problem is back.
  • Richard Lynch May 27, 2011
    Hi Mark, thanks for your suggestions. I have some more information. The mower is a CC989. Today, looking more closely at the Drive Clutch cable adjuster, a thumbwheel labeled TIGHTEN in small raised letters on the black plastic, I saw what I hadn't noticed before....an arrow indicating the direction was COUNTERWISE to tighten. I had actually loosened the adjustment as far as it could go! And it has been that way for quite a while. When I tightened in the right direction the clutch handle actually moved away from the hand bar. Great, I'll just go a try it out with the new adjustment.....no soap! O.K., lets try the adjustment at many places....still no go. At this point I had started to mow my lawn so I just kept going. Not much fun pushing that mower, on a sloping lawn yet, in South Carolina heat. Sure enough, after about 10 minutes it started working flawlessly. The operator's manual suggests if drive doesn't work, clean out debris. There's no debris that I can see.
    Your thought that the belt softens seems to be the best bet but the NoGo to Go so suddenly is very strange It's almost like a stuck part comes loose.
    Thanks, ****
  • 11,800 Answers
Transmission problem - either the clutch plate is worn out (you will need to replace it and correctly readjust the lever) or the belt is slipping, either because it's loose (the tension spring is worn out and has softened (replace it) or the pivot points are rusted and no longer move freely - oil it) or it has aged and it will have to be replaced.
You will need to dismantle the transmission for that.
Posted on May 28, 2011
  • 776 Answers
The drive belt is too lose or warn. The heat from spinning for 15 minutes softens the rubber and causes it to engage.
I would try tightening it (first), it may only help for a short period (few mows).
Eventually, you will have to change the belt (belt costs about $25).
Another possible problem is the "clutch wheel cable" (about $20 for new). It may just need to be adjusted if it is not pulling the drive mechanism tightly to the plate on the drive axle (take it apart to see how it works - it will be obvious). There are no good images on the internet for me to show you. Don't buy a cable unless you are sure it is broken - yours is not broken if it starts working after 15 minutes.
Good luck and remember to check back and let me know how things work out.
-Mark
Posted on May 27, 2011
  • Mark T
    Mark T May 27, 2011
    Unfortunately, it could also be that your transmission unit is going bad. This is unlikely since it will engage after some time - usally not the case (they just quit completely). Most likely your belt is loose or needs to be replaced.
    Page 26 of the manual says to have the drive belt changed by a dealer.
    http://www.cubcadet.com/wcsstore/CubCade...
    This may not be your exact model but likely works the same. If you have the tools and mechanical know-how, no reason not to try it yourself.
    -mark
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
How do I adjust the Governor on my Cub Cadet Self Propelled Lawn Mower?
To adjust the Governor will require the use of an tachometer. The speed is set from 3200 to 3600 rpm's by bending the tab where the spring attaches. We set the rpm's to 3350. This is a safe operating rang. Good Luck.
Thanks; George'
Sep 19, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Where is the idle screw located on my cub cadet SR 621 rear wheel drive-self propelled push mower
My guess is that there might not be one. Mowers usually are controlled via a governor spring/linkage and throttle spring/linkage. That might not always be the case, but there is a good chance that there isn't one. Do you have a manual? It would be on the carburetor somewhere if it did have one. Chances are it doesn't.
Aug 16, 2013 | Cub Cadet Garden
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
Garden Logo
725 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
