Error 0210 stuck key 42 Problem is coming and not starting at all Lenovo T60 LAPTOP
imatek1
SOURCE: ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Posted on Apr 27, 2009
  • 109 Answers
SOURCE: 0210: stuck key 2B
Find a replacement keyboard for your model online, and/or have a local computer shop install it (or order and install it) for you.
Posted on Dec 28, 2009
  • 561 Answers
SOURCE: when starting my Lenovo Think Pad laptop T400
Hi
Thank you for your query
Please try the following
1) Hook up a external keyoard to the USB/PS2 prot and see what happens
2) Press all the keys several times when the laptop is switched off to ensure that the keys are not stuck i.e. with debris etc etc
if this fails it would seem you have a bad keyboard, and would be looking at getting replaced
Please leave feedback/vote if my answer was helpful
Posted on Feb 12, 2010
  • 111 Answers
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Posted on May 04, 2010
tagmonkey2k
  • 117 Answers
SOURCE: Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Posted on Apr 19, 2011
Lenovo R400 Error 0210 stuck key 5b
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Aug 19, 2016 | Lenovo ThinkPad R400 Notebook
Komputer saya ada tulisan "ERROR 0210 : Stuck key 3c" kira kira laptop saya kenapa ya tolong dibantu dan apa yang harus saya lakukan
Biasanya , hal ini disebabkan oleh singkat di keyboard atau mekanisme kunci rusak . Cara mengatasinya biasanya untuk menggantikan keyboard . Ones dari T60 , R60 , T500 dan W500 semua akan bekerja sebagai pengganti . 3E harus kode scan, sehingga 3E akan menjadi nomor " 9 " .
Jul 02, 2016 | Computers & Internet
Fix error code 0210 stuck
error0210 is probably the O key. I found this information from Lenovo Service Site. Hope it is usefull.
You can test your key codes on this site, and as others have already discoverd and from my past experience key code 28 indicates that your error is coming from the apostrophe key. Sometimes due to normal use, keyboards may not fully release a key after it has been pressed. I would recommend getting some compressed air and try cleaning the keyboard, it is possible something is stopping it from releasing.
Since it seems that you are having mulitple errors I reccomend is to verify that your drivers are up-to-date, you can do so from the Lenovo Driver Matrix.
However, if this does not fix your error, it is possible the error has something to do with the BIOS Settings. You may boot to the BIOS and set it back to factory settings and check if the issue persists. To enter BIOS press the F1 immediately after the logo screen appears. Prior to the reset back up all of your information so that you do not lose anything as a precautionary measure.
Also, as others have stated if your device is under warranty, you may contact your local Lenovo Service Center for further assistance.
Dec 11, 2013 | Lenovo ThinkPad Computers & Internet
Error 0210 stuck key 3a
You going to need to find a new keyboard for this unit. Try ebay.com you might get lucky paying $20 or so..
Aug 08, 2012 | Computers & Internet
ERROR 0210: Stuck key 7B Press F1 to setup . Please help me out of this problem.
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Jul 20, 2011 | IBM Lenovo ThinkPad T61 Notebook
When starting my Lenovo Think Pad laptop T400 there is an error message 0210 stuck key 50, what does this mean and what shall I do
Hi
Feb 12, 2010 | Lenovo ThinkPad T400 PC Notebook
Oct 17, 2009 | Lenovo ThinkPad R61i Laptop
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
Computers & Internet Logo
2,229 people viewed this question
David Payne
David Payne
