Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
My floormate leaks water on the floor in puddles, even when I am not holding down the lever to wash.
    New Friend:
Ok when replacing the Spring stem and rubber seal. Put the spring on the stem set it in the hole of the solution tank carefully hold it steady then pull the stem out slip the rubber seal onto the stem with the cupped side facing down toward inside of the tank press it over the rim on the stem so it stays in place then take the stem slip it into the solution tanks hole inside the spring and press the rubber seal into the inside of the tank.
I posted this so no one else goes threw the trouble I went through until I figured it out for my self I lost the parts and did not remember how the thing went back together and could find no help anywhere. Good Luck, Ray
Posted on Jul 04, 2016
5 Suggested Answers
n1wgk
  • 84 Answers
SOURCE: I hav a floormate, it
I had the same problem. I brought it into a repair facility and they took care of it. It appears that the trigger mechanism is a plastic shaft that warps over time, so what they did was to "extend" the shaft so when I pull the trigger, it actually pushes the plunger up farther and allows more water out.
You can test this by taking out the top water tank and manually depressing the plunger on the bottom, does water come out on your hand? (do this over the sink! :-))
When you look at the seal on the unit itself, does the plunger go up and down a little when you pull the trigger? If there's a small amount of water in the little "cup", does it go down?
Posted on May 09, 2008
  • 8 Answers
SOURCE: hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Posted on Aug 29, 2008
SOURCE: Dirty water is not going into the tank, it's leaking out the bott
i would check the lower hose assembly. it seems they wear out where the handle closes and opens put the handle down and look in to see if its broke. if so its only like 20 for a new one and a pain to get the old one out....
Posted on May 12, 2009
  • 15 Answers
SOURCE: troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
Posted on May 25, 2009
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I just bought a hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the brissles at all. Help please. It is brand new. any ideas???
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=603805
I just bought a Hoover
Posted by serdmann4 on May 17, 2008
I just bought a Hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the bristles at all. Help please. It is brand new. Any ideas???
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I hav a floormate, it is just new and I can't get the water to release on the floor to wash it. I have the dial turned to wash and I do not get any water, the brushes do turn, but no water.
May 08, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Will not let the water down on to the floor.
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Nov 08, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate problem
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
364 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
