Hi, I found an RCA RT2390 home theater system thrown in the trash... It works fine... the only thing i can not do is change the tuner frequency...please help... no remote... I am trying to use an RCA system link 5 av remote... works all except tuner freq. change... thank you very much for your help... Bobby
  • 3,247 Answers
I am assuming you already have some sort of a user manual for it. If not check this site.
Unfortunately there is no option but to use a remote control unit for selecting the tuner frequencies both in AM and FM.
There maybe some unique coding techniques that are needed to select the right code for the tuner functions. I am assuming the unit was trashed because of the lack of appropriate remote controller being available.
Posted on May 26, 2011
Can i use the RCA subwoofer output jack?
The subwoofer jack might be switched off. Have a look under the menu of the system to see if it is off.
Apr 29, 2016 | RCA RT2390 System
Why do my RCA Model RT2390 gets hot and cuts off
Hmmm, lack of ventilation, shorted speakers or wire, excessive volume?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2390-Home-Theater-Systems-manual/id/402ag604/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 28, 2011 | RCA RT2390 System
Is there any way or solution to use RCA RT 2390 for a power supply of 220V?
No,unless you somehow modify the power supply by putting a 220vac to 115vac transformer.If you just used it without the mod, it would probably catch on fire or something like that.
Dec 25, 2010 | RCA RT2390 System
Optical audio doesnt seem to work... Does it need to be turned on and if so how do i do that?
put source on SAT. use the remote and hit "set up" use right arrow button until the word "coax" shows on unit, Now your digital.
Good Luck
Oct 14, 2010 | RCA RT2390 System
Rca rt2390 lost remote 5 years later lost electricity reciever reset and no optical input designated cannot designate optical to input source without remote...help
I found somewhere called newremotecontrol.com they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Feb 19, 2009 | RCA RT2390 System
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
Freezes up
your system needs to be servicedtake it to a tech and have him clean it up.
Feb 17, 2007 | RCA RT2390 System
 Grubhead
Grubhead
