Question about MSI X58M Intel Core i7/Intel X58/6 DDR3-1333/ATI CrossFireX/GbE/R/A/1394/MATX Motherboard
I have a msi x58m motherboard with i7 950 processor and 8gb ram and 850w psu. i had to purchase a new psu as the old psu had nearly blew up and caused a spark from the back of it. now when i boot up the pc with new psu it runs as all fans are running and the motherboard light is showing but there is no display shown on the screen as well as this there are no bios beeps could it be that the motherboard has actually gone?
  • JDTec
    JDTec May 26, 2011
    It may have taken out the Processor and/or the system bd.
    Problem Solver:
  • 10 Answers
Change motherboard if not fix problem after change bios jumper
Posted on May 28, 2011
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
I have MSI N 1996 MS 7312 VER 1.0 K9MMV motherboard and SEMPROM 1.8GHz processor . But I want to take AMD ATHLON x2 5200+ processor . And I want to take 2GB DDR2 800FSB ram. so please help me can I take...
If you have already bought the other components that you would like to add then this should be fairly easy. To replace the processor first you need to remove the original one. Start by taking off the heat sink, a large piece of metal near the RAM. This should be done by either screws or push pins. Once this is off pull the metal lever near the processor to the side. Bring that lever up and remove the old processor. Put the new processor in. There should be markings as to which corner goes where. Next you need to apply some thermal grease on top of the old processor. If you don't have any you can buy some here (http://www.newegg.com/Product/Product.aspx?Item=N82E16835100302&cm_re=thermal_paste-_-35-100-302-_-Product). Apply about a pea worth of thermal grease on top of the processor. Make sure the heat sink is clean before putting that back on. Normally it is a good idea to clean it off with a paper towel then some rubbing alcohol. Then reattach the heat sink and be sure to plug in the fan if there is one. Replacing the RAM is much simpler than the processor. Push down on tabs containing the old RAM and it should come out. take the new RAM and place it into the slot the old RAM was in and push down until the tabs come in and lock the RAM into place.
May 11, 2011 | MSI K9MM-V Motherboard
Advent T9400 dead motherboard
First replace the PSU, (it might be badly damaged - not only the fuse) and if you were unlucky enough to blow the chipset too it won't start even after the PSU replacement.
May 30, 2010 | Computers & Internet
Whats the best graphics card for msi 865pe that i can install?
It depends on your power supplie processor and ram.
id go with a 1000w powersupply
at least 8gb of ram
3.0 Quad Core processor
then slap x2 GeForce GTX 295 CO-OP Edition
Mar 06, 2010 | MSI 865PE Neo3-FS Motherboard
Need graphics card supporting the msi k9mm-v motherboard
here are the cards that you might be interested in.
Series 1
Series 2
Any one of these cards are the best AGP card you're gonna get. Only thing is, make sure your PSU is up to par. You will need at least a 450 watt psu.
It will be effective if you have 2gb RAM and Dual core processor.
Nov 28, 2009 | MSI K9MM-V Motherboard
PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
May 04, 2009 | MSI K8MM-V Motherboard
I have a problem with my ram
That motherboard does not have a video circuit built-in, so the video sharing the system RAM does not make sense.
Have you checked the valid system memory configurations in your MSI manual pg 2-7 ?
Any chance that the bios is set for dual channel and you don't have equal chip sizes in the dual slots? Example : In dual-channel mode, equal size chips would go in slots 1 & 3 and in 2 & 4
Defective RAM is a possibility also.
Note1: Per MSI, all ram may not register correctly in windows unless 4 of the 2GB chips are used
Oct 25, 2008 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Aug 15, 2008 | Gigabyte 8IG1000MK Motherboard
Serious problems with an Asus M2N E SLI motherboard.
I understand how this must be driving you nuts. What I am going to suggest might sound stupid but I have to ask. After your assembly was finished (1st time around) did you check the 4-pin ATX + 12volt connector was correctly & fully inserted into the board? Pg. 2-28 section 6. in your manual? Did you add thermal grease to the CPU. A bad pin on the CPU will give you this symptom. I completly understand if you do not agree with this next part but it is extreamly important you go with it. Take the static bag your board was wrapped in & lay it on a table. Place a piece of foam on the static wrap & place your motherboard on the foam. You can use books instead. Connect your PSU, CPU heatsink & fan, Hd & video card & 1dimm to motherboard. Connect mouse, keyboard & monitor.
Check that PSU is set for 115v (small red slide switch near the off/on toggle switch). Plug in the PSU to outlet.
If the green led on board lights up you have power to board. This is known as a standby led. If it's not on, flip the toggle switch on the PSU to on.
Use a pen to short the power switch. This will turn on the board, no different than you pressing the power button on your case. Goto pg. 2-30 in your manual. Find PWRSW two pins. If the system starts up than somewhere durring install the board was shorted to the case.
Feb 16, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
MSI X58M Intel Core i7/Intel X58/6 DDR3-1333/ATI CrossFireX/GbE/R/A/1394/MATX Motherboard Logo
99 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
