Question about Olympus Stylus 700 / 700 Digital Camera
On start up the camera does not focus, the lens then retracts, and a blue screen appears on the view finder, with the codes 5f o8 & 5e o2 displayed. The camera is 4 years old at least, I am still using the original battery. It has been used in rough conditions in Antarctica & most recently in high humidity in mato atlantico on east coast of Brazil, in Rio Janeiro state. when problem occurred. Battery state indicates that it is charged.
  • nickhalls_co May 26, 2011
    Read through all on line references to the problem on Olympus website, and tried the various solutions.
    Charged battery as this was highlighted as a potential problem, and cleaned all connections of battery to body of camera. Cleaned the lens mechanism with designated cloth for task, and ran a corner of a piece of paper round the crack between rings separating the lens extension mechanism to see if that might remove dust or grime.
    Got the the camera to work without a memory card installed and took some photographs using the camera memory. It worked ok, so nothing fundamental seems to be wrong. Cleaned round fully extended rings of lens. Thought I had cracked it.
    However with recharged battery and memory card installed the camera went back to blue screen and 5f 08 & 5e 02 codes, with lens failing to come out completely and then retracting.
    Tried hitting bottom of camera while lens came out - no reliable result so far.
    Any further advice you can offer would be appreciated.
    Nick Halls
  • 17,970 Answers
There variasOlympus lens error 5e02 5f08 5f08 340th (lens error)
For usblsb
The Olympus has released a breakdown that makes the screen turns blue and leave a message with the NEXT error codes.
340th 5f08 5f08 5e02
This series of code representing a total in this case of four errors.
There are several reasons that make the Olympus digital camera, display that error and all have to do with the lens.
Usually gives this error because the camera has been dropped and has a defect in the path of the lens or the gear or gear motor or lens.
I also found this bug when the camera has some kind of dirt such as sand in the lens mechanism.
Another cause in this brand and very common in the Stylus 700, Stylus 710 etc ... (as the lens mechanism is similar to many models whose only difference is usually the CCD) is caused by failures within the lens, these failures are the focus motor, oil spilled on the blinds or shutter, and I've also found this bug caused by the fault of a thin sheet that protects the PCBoard flexible shutter mechanism or focal motor, this thin sheet is folded crease and makes the failure mechanism of this form.
Check it and keep us updated.
Posted on May 27, 2011
    Sergeant:
    Champion:
  • 304 Answers
Hi, Unfortunately with that camera the blue screen is considered the blue screen of death. It's likely caused by the extreme situations you've used it in (as camera's like that aren't meant to withstand those kind of conditions). Some people who have gotten that error have found that hitting the bottom of the camera while the lens comes out works however the results are 50/50 so try at your own discretion. Another option, since this is a known problem with that camera model, is to send it into Olympus for repairs but you would be looking at a cost of at least $100US. If you need anymore help let me know and I'll try my best to help you out =)
Posted on May 26, 2011
View through viewfinder is dark, looks like dark sunglasses over lens. 24mm lens indicates fE E on lcd code. Shutter will not function or lens will not automatic focus. Switch to 70-300 lens, view finder...
Sounds like the aperture control actuator ring in the camera body is not opening the aperture diaphragm blades fully a repair quote and decide if a different body upgrade may be a better option
May 29, 2017 | Nikon N80 35mm SLR Camera
How to brighten the viewfind on a Nikon F 100
If you think the screen is dirty then you can remove the view finder screen inside the camera from the lens opening. Also, there are other view finder screens that you can purchase. Read page 65 of the F100 manual to see how to change focus screens.
Nov 04, 2009 | Nikon F100 35mm SLR Camera
Lens cycles in & out upon start up and view finder blurry.
Here's the procedure for a manual reset...remove the card and battery...press all the buttons...insert the card and then the battery...turn on the camera.
Sep 10, 2009 | Olympus FE-340 Digital Camera
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Feb 26, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Camera lens does not retract & view finder is just blue, will not go to other screens
The lens maybe out of track. Perhaps you have bumped the camera or dropped it. Look if the lens are a bit tilted, if so, try straighten the lens with your fingers, very gently. Hope it works.
Oct 04, 2008 | Fuji FinePix F470 Digital Camera
5f 08, 5e 02, Olympus 710, Help!
hi alexandra olympus cameras are know for having a few lens problems when ever a blue screen comes on the camera is faulty it sounds to me like you have some dirt or dust in the lens i have seen this problem a few times hope u get it sorted goodluck
Sep 28, 2008 | Olympus Stylus 710 Digital Camera
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Blue screen and error message
No solution you can make- The motor mechanism is shot Depending on how long you have had the camera you may get it replaced or a repair price quoted. The repair price will be horrific buy the next camera.
Sep 28, 2007 | Olympus Stylus 710 Digital Camera
Camera screen turns blue when turned on
Return it anyway if you have proof of purchase. Definately a dud camera to fail this early
May 09, 2007 | Olympus Stylus 710 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
