Question about Kenmore Dryers
Kenmore elite dryer when I put a load in this morning and closed the door and push the button nothing happens we have checked to make sure it had not blown a fuse and that it was plugged in correct I do not have a book is there a reset button whatg else can I check
    Brigadier General:
  • 3,301 Answers
Check the thermal fuse in the back
Posted on May 26, 2011
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
Kenmore elite washer troubleshooting
The most common cause of this is the switch that tells when the door is closed. Please post the make and model
May 22, 2013 | Sears Roebuck And Co Kenmore Drain Hose...
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Kenmore dryer doesn't recognize when the door is closed.
first try unpluging the dryer for 5 minutes and then check it,this resets the computer board just like your house computer or you could have a bad door switch or something wrong with the main board,the main board is alot more than the door switch,if you have a meter you can read out the door switch,there should be a tech sheet in the dryer maybe taped to the side wall behind the bottom panel that might help you out.
Jan 14, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 dryer will not start
Not sure what it is but have you checked the door switch? Maybe a loose wire there? or a bad switch?
Sep 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
First time use, not working
The door switch is not closed or the board is not sensing the door is closed.
Push in at the top of the door to make sure it is latched at the top.
This is a common problem on the HE4's that was not a problem with the HE3's. We are hearing from Kenmore and Whirlpool that a fix is coming, a different latch I think.
Even if pushing in at the top makes it work, call for service so the problem can be addressed.
Post back if you have any questions.
Nov 12, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
