Question about LG 32LC2D Television
LG 32LC2D-UE, when tv is turned on for the first time of the day, power light blinks about 11 times, black light comes on, no picture and a high pitch squeal. I have to hold the power button in for about 10 seconds to turn it back off. It does it about 2-3 times before tv functions normally.
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
same here How do you change the Power regulator?
Posted on Jan 28, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
gsalmen
  • 77 Answers
SOURCE: LG LCD 37
the main total assy is at fault. unplug the tv for 5mins and plug it back in. if it does not clear itself it needs factory service
Posted on Jul 09, 2009
freelance-au
  • 131 Answers
SOURCE: 61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Posted on Mar 05, 2010
  • 38064 Answers
SOURCE: After turning on LG model 47lh40-ua the TV blinks 3 times then turns off
Open internal fuse or power supply failure
Posted on Jan 10, 2017
Lg led tv doesn't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices....
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 20, 2016 | LG Televison & Video
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
? 3:16
Dec 20, 2015 | LG Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
LG 32LC2D tv is taking 35 minutes tu turn on
If you can darken the room when first turn set on and have sound, take a small light (flashlight) and examine the screen, DO YOU see a faint image of the picture on the sets screen?
Most use a back light and it may not be coming on correctly.
To learn more Google BACKLIGHT IN TV.
Dec 12, 2012 | LG 32LC2D Television
LG 32lc2d tv - blinked several times and then froze. Whern it unfroze it turned itself off. Now when it comes on, there is no picture, no sound. Any answers? Thanks
This sound like the power supply board has failed. This is usually because of bad electrolytic capacitors.
A bad batch was made several years ago and many manufacturers used them is all sort of products. THIS IS A INDUSTRY WIDE PROBLEM.
IF you know how to repair electronics or have a friend with knowledge/skill you can replace thems.
> Unplug the set.
> Remove the back cover.
> Look at the capacitors on the power supply board.
> If any capacitors have a bulging top you've found the problem.
> You need to get good new replacements.
>The farad rating must be the same.
>The voltage rating can be the same or higher voltage. (never lower)
>Use high temperature rated ones.
> Replace one at a time to prevent mixup.
> When soldering in leave a space between the PC board and the bottom of the capacitor. They need room to expand due to heat.
> While you have the board out you should replace the other capacitors before they fail. Maybe not the biggest one however.
NTE make capacitors. Website nteinc.com. You should be able to find there local outlet. You can also look at;
http://lcdalternatives.auctivacommerce.com/Repair-Kit-LG-32LC2d-LCD-TV-Capacitors-P1747193.aspx.
Feb 13, 2011 | LG 32LC2D Television
LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
Aug 31, 2009 | LG 47LC7DF 47 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
80 people viewed this question
Computer Repairing
Computer Repairing
