Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
When the water sprays out leaves water lines on carpert . shouldn't the water spread out
Http://www.youtube.com/watch?v=QBtWcC4gqjY
I found this solution on youtube. I believe the vacuum motor for the pump is not working and needs to be cleaned and oiled. See the video.
Posted on Jul 22, 2013
I Am having the same darn problem...Grrrr...Can anyone help???
Posted on Jun 25, 2013
How do i hook up for upholstery & stairs?
Posted on Jun 14, 2011
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Streaks on porcelein tile from shark steam mop
Try washing your pads in JUST water and Baking soda or Borax (and only about a tbs). Sounds like a hard water problem. I had the same issue with my wood floors so I put some Murphy's Oil in a spray bottle and it polished my floors while I steamed. Perhaps there is a good tile cleaner/polish you can spray with a spray bottle while you mop? Just a suggestion. I haven't had this particular issue with tile (our floors are concrete and wood) but the streaks went away when I started using just Borax in my laundry with them, no fabric softener, no dryer sheets. My mom used to use Isopropyl alcohol in a spray bottle with her steam mop. Make sure your tile is well seeled too, it gives you a better finish. The alcohol dries on it's own too without leaving residue.
Jul 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
WATER LEAKING IN MY CYCLONE RV
Maybe you shouldn't have moved your girlfriend up to North Dakota with you. I'm sure that it is her fault that your water is leaking in your RV.
Nov 04, 2011 | Vacuums
My proheat cleaner won't spray out any water even after repeated tries with the trigger. Lots of water in the tank and it's on the floor setting
Could be and air lock. Bleed the system so you know there is water in all the lines. This will also determine if there is a block in any of the lines. Also try the input hose filter, if there is one.
Jun 10, 2011 | Bissell Vacuums
It won't spray water!!
I have a model Bissell Proheat Platinum II Model 1699 that was not spraying. It looks to be very similar to your model. From reading other posts, this is what I did:
Frst make sure it isn't the pump. Try spraying with your accessory. The accessory does not use the heater. If you get spray with your accessory, your pump is okay. If you don't get spray, check the belt to the pump. If it isn't the belt, you may need a new pump.
Luckily, I got spray with my accessory, so now you need to check your tubing from and to your heater. As stated in other posts, the heater is located within the lower half of the handle where the POWER HEATER switches are. There are quite a few screws. It's easy to miss the one at the very top of the handle. First remove the accessory caddy and then remove one half of the upper handle. The other half of the upper handle lifts straight up allowing you to split the lower part fo the handle into a "V". It pivots at the bottom around the wheels. It took me a while to figure out that I needed to LIFT that part of the handle straight up.
Once you split the lower half, you will see the heater (aluminum box). There are two ports on the heater where the two lines connect to the heater (in and out). Use pliers to loosen the spring clip where the tubing connects to the heater to remove each line. My lines were okay. One of the ports on my heater was plugged. I used a 1/16" drill bit and hand reamed out the crud. You don't need to use a drill -- use your hand - it's safer. After you cleaned out the ports and your tubing (if needed), suggest you try it out after reconnecting the lines to the heater but before you put the handle back together. You may find that the lines or port needs more cleaning. Make sure you have water in both the water and cleaning solution vessels. As you know, no water will spray if EITHER one is dry. Turn it on and then press the little spring that's still in the handle. Hopefully you will get a water spray.
When you put the handle back together, be careful that you don't crimp the tubing. Tuck them back in the notches in the handle.
Hope this helps . Good luck.
Feb 20, 2011 | Bissell 1698 PowerSteamer ProHeat Upright...
My shampooer leaves a line of water. doesn't spray the area
Make sure you have the proper dispense of shampoo in your tank. Also try taking the speed down a little. If that does not work look at the video for further instructions
Oct 20, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Bissell ProHeat 2X and cannot get water to suction back into cleaner once dispensed on carpert
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wtgd
Nov 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
417 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
