LaserJet P3015 is loud and you start to use the tray 1 moves repeatedly input tray and roller if all papers using loads very quickly leaving stuck in the fuser. the tray 2 works fine.
  • eudalt May 28, 2011
    the sount is not a bearing or fuser is the tray that lif up and down continuously only in tray 1
    and roller of this tray do not stop when carge paper.
    thanks you
    Scholar:
  • 118 Answers
If the printer is loud ( loud buzzing sound ) then is caused by two things. 1. The fuser pressure roller bearings are worn and 2. the fuser drive gearing on the left hand side of printer ( as you look at it from the rear ) may also be worn.
I have replaced bearings before but they dont seem to last for long. A new fuser is the best option.
Posted on May 26, 2011
  • 7 more comments
  • Col Johnson May 29, 2011
    Ok so the problem is with the paper pickup in Tray 1 only. By your description I am assuming that the paper is getting pickup up but the pickup roller keeps turning and picking up more paper, is that correct?
    Or is it pucking up multiple sheets of paper?
    Check that the separation pad ( under the pickup roller ) has a cork or rubber surface. I have found that missing in some cases which causes noise and pickup issues.
  • eudalt Jun 03, 2011
    the printer func anormal because not stop pickin paper on tray 1 moves repeatedly up and down
    and not pause on a paper inside.
  • Col Johnson Jun 05, 2011
    I think I understand now that the Tray 1 ( MP Tray ) paper pickup roller keeps rotating when it should,nt. You need to take the right hand side panel off the printer and watch the rotation of the gearing on the end of the shaft that holds the pickup roller. Watch to see if the solenoid is operating, i.e. opening and closing onto the white gear/clutch.
    If it is opening and closing then the problem is with the white gear & clutch.
    If it is staying open then the printer has either a faulty solenoid or faulty controller board.
  • eudalt Jun 05, 2011
    thanks i should prove this, have you a service manual? to make right and find more information.
    Sorry but I dont have a service manual. The right panel comes off easily so you should,nt have any problem in examining the mechanism.
  • eudalt Jun 10, 2011
    i have extranct left and right panels i see that is the gear but i dont know have solution
    the problem persist
    the gear is not full is truncatet i dont now is right
    thanks
  • Col Johnson Jun 10, 2011
    Sorry but I dont understand what you are saying. When the paper pickup roller is turning you need to look at the solenoid to see fi it is opening and closing.. If it is not then you have have a defective solenoide or controller board. If it is opening and closing then you have a defective clutch. That is the white gearing on the end of the shaft of the paper pickup roller assembly. I cant explain it any better than that.
  • Gimosuby Jun 27, 2011
    I have the same problem. Eudalt, did you get this problem fixed and what was it?
  • Gimosuby Jul 04, 2011
    Here is the real answer. I've talked to a HP tech. The metal solenoid plate needs to be re-aligned. You can find documentation on how to do that here:http://www.2shared.com/document/AAIQCT2w...
    Hopes this helps someone.
Paper will not feed
Both paper tray and rollers are spring loaded.
If you have paper stuck in the feed area, it will not pick up paper.
Try removeing all from unit and power blowing the inside try area.
Feb 11, 2014 | HP Laserjet Pro Cp1025nw Color Printer
Tip
Moves repeatedly input tray 1
on May 26, 2011 | HP Laserjet P3015X Printer
My HP laserjet printer is showing Out of paper repeatedly. How to fix it?
the out of paper erro can also be caused by worn pickup rollers. These rollers are used to pickup paper from the paper tray and feed it into the printer. When they get worn down they can't grip the paper to pick it up so the printer thinks the paper tray is empty. The pickup roller runs $3.99 and can be installed by the end user, no service center is needed. The part number is RL1-0266 and looks like this:
We carry them in stock if you would like to order one here:
http://www.ccl-la.com/catalog/product_info.php?products_id=202
I hope this helps, if so please rate my solution.
BuddyMc
Feb 09, 2012 | HP LaserJet 1018 Printer
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
My HP LaserJet 3050 will not grab and feed paper from the paper tray but will print on single fed sheets when fed to the input above the paper tray. What is wrong?
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Sep 04, 2009 | HP LaserJet 3050 All-In-One Printer
Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    Attention Light Is Rapidly Blinking Orange
    sorry I got it, usually you may try:
    1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
    2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
    3) check input roller and cartridge unit and fuser unit at running condition when the power on.
    anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
    Dec 24, 2008 | HP LaserJet 1300 Printer
    Printing problem with HP Laserjet P2015 printer
    This can be an issue with one of the faulty sensor across the printer.
    Please check if you are able to print from tray 1, e.g. a configuration page.
    A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
    If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
    Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
    If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
    Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
    CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
    Figure 1: Unplugging the power cord
    mma01_13245_0
    2. Open the print cartridge door, and remove the print cartridge.
    Figure 2: Removing the print cartridge
    mma01_13246_0
    3. Remove the main input tray (Tray 2).
    Figure 3: Removing the main input tray (tray 2)
    mma01_13247_0
    4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
    Figure 4: Opening automatic two-sided path door
    mma01_13248_0
    5.Place the printer on the work surface with the front of the printer facing up.
    Figure 5: Placement of printer
    mma01_13249_0
    6. Pull the white tabs outward, and rotate the tabs up.
    Figure 6: White tabs
    mma01_13250_0
    7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
    Figure 7: Right tab movement
    mma01_13251_0
    8. Slide the pickup roller assembly to the right, and remove the left end cap.
    Figure 8: Pickup roller assembly movement
    mma01_13252_0
    9. Remove the pickup roller.
    Figure 9: Pickup roller
    mma01_13253_0
    10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
    mma01_13254_0
    11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
    Figure 11: Pickup roller end cap
    mma01_13255_0
    13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
    Figure 12: Closed automatic two-sided path door
    mma01_13256_0
    16.Reinstall the print cartridge, and close the print cartridge door.
    Figure 13: Print cartridge
    mma01_13257_0
    17.Plug the printer in to turn it back on.
    Figure 14: Power cord in
    mma01_13258_0
    Cleaning the pickup roller
    Perform the following to clean the pickup roller.
    1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
    2. Dab a lint-free cloth in water, and scrub the roller.
    mma01_13259_0
    Figure 15: Scrubbing the roller
    3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
    mma01_13260_0
    4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
    mma01_13261_0
    Figure 17: Reinstalling the pickup roller
    Oct 27, 2008 | HP LaserJet P2015dn Printer
    Automatic Paper feed
    Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
    Sep 06, 2007 | Samsung ML 1210 Laser Printer
    731 people viewed this question
    k24674
