Question about Cell Phones
HOW TO INSTALL, PROGRAM, CROSS CONNECT, ETC. ??
  • brucetulsa May 26, 2011
    This is not a phone. It is a MITEL CM1470 LOOP TO GROUND CONVERTER FOR PBX'S or KEY SYSTEMS. IF NO ONE THERE HAS ANY INFO, PLEASE RETURN MY MONEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 3,530 Answers
Welcome to Fixya
Sorry. Could you provide more details on what you want to do to your cellphone? Would it be possible also if you can provide the cellphone's brand and model.
Your response will be greatly appreciated.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on May 27, 2011
  • brucetulsa May 29, 2011
    THIS IS NOT A CELL PHONE!!!!!!!!!!!!!!!!!!!
    IT IS A MITEL CM 1470 LOOP START TO GROUND START CONVERTER.
    THIS PICE OF EQUIPMENT IS FOR KEY SYSTEMS, and or PABX'S.
    IF YOU DONOT KNOW THE ANSWERE PLEASE REFUND MY MONEY!!!!!!! THANK YOU.
    THIS IS THE THIRD TIME I HAVE SENT THIS SAME INFO.
    Genius:
  • 1,098 Answers
Hi there.
It would help to let us know the brand and make of your phone.
Thank you.
Posted on May 26, 2011
What boards are applicable on OSN 1500B?
List of cross-connect board Q2CXL1 1xSTM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL4 1xSTM-4 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL16 1xSTM-16 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q5CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1PCXLN SCC unit, cross-connect unit, optical interface unit integrated board Search SCC
Jan 23, 2017 | Computers & Internet
Red cross flashing on screen
This means the application has not loaded or it has an issue with the application. Download the full instructions from tomtom website to reinstall you tomtom with fresh application and program etc. YOU MUST back up your device first and ensure you have a copya of the map as you cannot download this. make a backup first and use tomtom home program to install the new application, copy your map back to the device etc. the instructions from tomtom are pretty straightforward to follow. Also contacting tomtom support will get you help in reinstalling the application.
Sep 30, 2013 | Tomtom One IQ Routes GPS Receiver
The image is cross how to get correct printing
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Canon LASER SHOT LBP-2900 Printer
How to connect phone internet to the computer
Mr. Raj
Is ur mob is a modem supported? eg Nokia N 73 etc..
then install the phone browser program in the computer, with CD ROM along with the mob. Then 'connect to the intrnet option' and follow the instructions
Mar 26, 2010 | LG KG800 Cellular Phone
Really need some help changeing alt on 2000 intrepid
  1. Disconnect negative battery cable.
  2. Raise and support vehicle.
  3. Remove lower plastic splash shield.
  4. Remove transmission cooler and reposition cooler out of the way.
  5. Remove lower radiator cross member support and position a jack stand under radiator for support.
  6. Loosen adjusting T-bolt, but do not remove.
  7. Loosen pivot bolt, but do not remove.
  8. Remove the generator drive belt.
  9. Disconnect the generator field circuit plug.
  10. Remove the B+ terminal nut and wire.
  11. Remove pivot bolt, being careful not to lose spacer.
  12. Remove generator.
INSTALLATION
  1. Install generator.
  2. Install pivot bolt, leave loose.
  3. Connect the generator field circuit plug.
  4. Install the B+ terminal nut and wire.
  5. Install the generator drive belt.
  6. Adjusting T-bolt and tighten belt.
  7. Remove jack stand from under radiator and install lower radiator cross member support.
  8. Reposition transmission cooler and tighten fasteners.
  9. Install lower plastic splash shield.
  10. Lower vehicle.
  11. Connect negative battery cable.
Jan 13, 2010 | 2000 Dodge Intrepid
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Adding new extension to Nortel Norstar Meridian Phone System
They should have terminated your voice on a block in your phone room. If that is the case you now need a punch down tool and a spool of cross connect wire. You would punch down one side of the cross connect wire on the tip and ring of the switch pairs and the other end of the cross connect wire on the blue pair of your station cable.
Jan 15, 2009 | Lands Phones
I have tried to install Windows Lifecam on my IBM laptop running XP Pro. Every time I install it I lose my network connections and cannot connect or even view my ip properities, network connections, etc. I...
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 06, 2009 | Microsoft LifeCam for Laptops
Please help me fixing my gps
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
Dec 22, 2008 | Tomtom One XL GPS Receiver
Cell Phones Logo
142 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
