Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
One of the 3 bars inside the dryer drum has come loose... one or two of the bolts / screws that hold the piece to the side of the drum vibrated loose leaving the bars to flop around, being held by only one bolt/screw. How do I get the top open in order to spin the drum into position to replace the bolts? Thank you
    Brigadier General:
  • 3,301 Answers
This will give you some insight on how to proceed http://repair2000.com/wpoolbelt.htm
Posted on May 26, 2011
  • dr_bud May 27, 2011
    Thank you very much. The information was great, however, I wasn't able to get the lid to unlock. Your response was prompt and courteous. LCM
The bar things inside the dryer drum (there are three of them) one has come almost all the way off. and one is loose. looks like its screwed from the other side.. cant figure out how to get inside. it...
Unplug the dryer. Open the door and remove a total of 4 screws, 2 on each side of the door opening. Two screws each hold a clip in place and the other two hold the dorr hinges. When you remove the screws on the door hinge, it shouldn't fall off, but be prepared for it to do just that. The door should come off by lifting the hinges upward and pulling the door away. The remaining part of the front panel is held on by 2 clips located toward the top sides of the u-shaped front panel. Pull the panel forward to release the clips and lift the panel upward to clear the two tabs and slots on the bottom. On each side of the cabinet, there is a blackish colored metal bracket that holds the top in place. Remove the fasteners that holds these brackets and remove the brackets by sliding them upward and away. The top should now lift up. You now have access to the fasteners that hold the baffles onto the drum. If , for some reason, you should want to remove the baffles, carefully note the different sizes of the baffles and what order they came off.
Here is the parts list for the drum of your dryer:
http://www.repairclinic.com/Maytag-Model-MDE3500AYW-ID-508609-Drum-Or-Tub-And-Related-Parts
Good luck from Detroit, MI.
Jul 18, 2011 | Maytag Dryers
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
One of the plastic pieces inside the dryer drum is loose. How do I remove the dryer top so I can tighten the screws>
OPEN THE DOOR. INSIDE THE OPENING ARE FOUR SCREWS 2 ON EACH SIDE. REMOVE THESE. EACH SIDE OF THE FRONT PANEL KIND ROLL OF FROM INSIDE TO OUT AT THE TOP. OR JUST PULL. BRING THE FRONT PANEL OUT TO A 45 DEGREE ANGLE. CLOSE THE DOOR AND LIFT UP ON THE FRONT PANEL. AT THE FRONT OF EACH TOP CORNER THERE ARE HOOKS HOLDING DOWN THE TOP. THEY ARE SCREWED IN PLCE WITH A 5/16 TH HEX HEAD SCREW. REMOVE THOSE AND THE TOP CAN LIFT UP.
Apr 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I HAVE A MAYTAG NEPTUNE DRYER. THE RIB ON THE
remove the toe kick front panel screws near the floor in front then lift up like a car hood to release clips at the top,then remove screws that hold top on,then you can get to the baffle screws to re attach
Jan 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi, We have a Neptune dryer that has lost all of its 3 fins.
yes this is to me, you have to take off the door, and panel, loose bolt that holds top to front panel and you will be able to turn the drum and reinstall baffles with screws, you may need to add a flat washer if the holes have stretched.
thanks
Aug 22, 2009 | Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
FIn inside neptune md55 dryer came loose need to remove side pane
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer vanes came loose... can't figure out how to remove front or top panel to access the outside of the drum in order to tighten the bolts/screws that hold the vane in place.
use a putty knife and about 4 inches inside on each side insert the putty knife between the frount panel and the top and lift up on both sides, the tub will be visable to the screw holes in the tub to reinstall the vanes
May 27, 2008 | Magic Chef Dryers
Noisy dryer
i had same problem with washing machine. i found out it was the stone inside which holds it down while it spins. The screws or nuts or what ever is holding the stone could be loose.
Or it could be the nuts or screws of the actual drum that spins that got loose when you moved the machine
Nov 10, 2007 | Washing Machines
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
