Question about Performance Teknique ICBM-774 Car Audio Amplifier
Hi I don't have sound of one channel, i want schematics diagrams AND help me please for fix STEREO POWER AMPLIFIER ICBM 774 Thank you very much Philippe GUSTAN
  • conceptservi May 27, 2011
    Mr. Woodring
    I will ask my client tomorrow morning, because I do not know if he was using 2 or 4speakers, it's dark now and I can not do so immediately.
    I am electronics engineer, so I could takes tensions on the four amp Pusch pull " or totem tole for to help you locate the problem: it will do tomorrow
    I would also buy the schema of the amplifier, you can sell me one. pdf?
    I'll reply tomorrow for the details that you asked me
    Cordially
  • 496 Answers
How do you have it wired as a 4 ch. or a 2 ch. the next thing i need to know if you have it hooked up for 8ohm 4ohm or 2ohm ? let me know
M.Woodring
Posted on May 27, 2011
  • mark woodring
    mark woodring May 27, 2011
    i'll be looking forward to hearing from you
    Mark
K-4040 left channel lost. How solve this problem?
Look for shorted capacitors and driver stages. You'll need an audio voltmeter and an oscilloscope to trace the signal path. A schematic diagram is a must.
Sep 26, 2016 | Velleman STEREO TUBE AMPLIFIER KIT /...
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
How would u bridge 2 fosgate punch hx2 to this technique ICBM 9550 2600watts
  • Hi, I can help.
  • As I look at the manufacturer specs and recommendations this amp is not brigable. I figure I would tell you so you did not ruin it.
  • When you bridge you turn 2 channels into 1 channel. This is already a 1 channel amp. Bridging would ruin that amp quick.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Performance Teknique ICBM-9550 Car Audio...
Proction light stays on
If it stays on even when the speaker are not connected to it then the amp is fried but f it goes off when the amp is hooked up with no speakers then check the Ohm load on the amp and wire the speakers to match that but don't go below the ohm load on the amp...this site will help.... http://www.crutchfield.com/S-ApB0sVuYqNs/learn/learningcenter/car/subwoofers_wiring.html
Aug 13, 2011 | Performance Teknique ICBM-774 Car Audio...
Red lightstays on no power how to fix
Sounds like something is shorting out and it is protection mode. Check that the wiring is correct and there are no bad spot on the power wires
May 25, 2011 | Performance Teknique ICBM-774 Car Audio...
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
Stereo channel
Hi again,
I was just checking other related questions when I saw your post. I am afraid that each would have to use separate inputs. Please check your original posting for added information.
Hope this be of additional help/idea. Pls post back how things turned upor should you need additional information. Good luck and kind regards.Thank you for using FixYa.
Nov 16, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Power Surging Threw Subs!?
Possibly a ground loop with a poor ground connection at the head unit or the amp. Sometimes a small difference in the ground can set up something like this.
Could also be a problem with head unit.
Do you have capacitors for handling power surge needs? These could possibly be affecting this.
Mar 08, 2008 | Performance Teknique ICBM-774 Car Audio...
It is almost obvious to me that the New Box is Unvented. If you went from Vented to non-Vented. there you go. The Amps and Subs should be doing the same thing. If your Sony 10's are designed for Vented they will not thump right in a NON-vented box.
Nov 28, 2007 | Performance Teknique ICBM-774 Car Audio...
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Performance Teknique ICBM-774 Car Audio Amplifier Logo
80 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
