Hotpoint washing machine WMA64 begins a wash (any selection) and within 1 min the display changes to On and the water drains as if the wash completes?
  • al58477 May 26, 2011
    It is plumbed with cold feed only. I tried cold wash and same thing happens? There is no error code or warnings - it just acts like end of a wash.
  • al58477 May 27, 2011
    Thank you for suggestions, they all point to need for a technician so I have to call in an engineer now. Thanks
    Brigadier General:
  • 3,917 Answers
If your washing machine aborts within the first few minutes of a wash it could be that the heater isn't working and it has detected the water isn't getting any warmer and timed out on heat.If the washing machine is not heating water it is caused by the following:-
Faulty Thermostat-This is a component that measures the water temperature. You need to call a service repairman to get it tested.
Faulty Heating element-Check the connections for loose or corroded contacts.
If no hot water is coming through the hose check to see if the screen inside the water-inlet valve is clean. If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Posted on May 26, 2011
  • e-Guru
    e-Guru May 26, 2011
    Since this machine has only cold feed then the problem lies elsewhere. Some washing machines will abort just after starting if they detect any one of the parts has a slight leak to earth. A megger meter is needed to check for this and only engineers tend to have them. Insulation tests involve putting 500 v CD through the machine.
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting fixya.com
  • e-Guru
    e-Guru May 26, 2011
    There is one more thing that needs to be checked if it's draining all the water then the failure is likely a stuck water level pressure switch. Your model could also have a flood switch too that is stuck causing the drain pump to come on. Testing the pressure switches will require an OHM meter. However this type of failure will likely require a service technician to diagnose and repair.
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
Could you tell me the load capacity to the hotpoint wma64 please
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
Jul 29, 2011 | Hotpoint WMA64 Front Load Washer
Pls my wma64 is not retaining water for washing, it releases water immediately the water goes into the machine. Pls what can i do ?
The most likely reason is that the drain valve is stuck open. If the unit is newer it can be caused by debris and might be cleared by repeatedly cycling the valve. If older the valve may have failed and will require a new one. Another less likely problem is the timer assembly that controls the valve.
Mar 05, 2011 | Hotpoint WMA64 Front Load Washer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
My machine starts a wash ,, fills then emptys with in 2 mins on any cycle
Sounds like your drain hose is not high enough or you have a tight fit where it goes into your standpipe. The drain hose should have a space around it where it goes into the standpipe or it will create a vacuum effect and **** the water right back out.
Feb 26, 2010 | Hotpoint WMA64 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
THE DOOR ON MY HOTPOINT WMA64 DOES NOT REGISTER AS BEING CLOSED
The most common cause of this is the sensor wire inside has vibrated loose and is no longer making a connection to the switch. Those switches rarely fail. It's a very easy fix, only need a screwdriver. I would, however, use a small plastic ziptie to hold the wire to the switch.
Oct 06, 2009 | Hotpoint WMA64 Front Load Washer
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
