Question about VeriFone Omni 3700
3750 File Group Password
Non Standard File Group Password.
How is this password recovered or reset to no password or the standard 1 alpha alpha 66831?
  • Anonymous Apr 08, 2009
    I have 3 of these machines and I sold them on ebay but was sent back due to can't get past the password. how can I get past this?
    mikeasseff@yahoo.com
  • hjenergy May 10, 2009
    I have the same problem. The old merchent company won't give me the password.
I have a Verifone VX570 that I purchased from someone on Craigslist. It appears that the machine is locked and/or encrypted by the previous merchant accounts provider, North American Bancard. I got past...
yes there is a way to reset it to the factory default password, but try BEERTIME first (23378463). if that doesnt work give us a call and blow the password out for you. (775) 358-2922 look for randy
Jun 10, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
I have an Omni 3750 that I bought from a provider. I have since switched providers and now my Omni 3750 reads "download needed no *go variable". My previous provider gave me several passwords...
Here's Some that you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jan 19, 2011 | VeriFone Omni 3700
How do i set my omni 3750 back to factory setting? hard reset?
If you wish to erase application.
it must settle the batch before formatting.
Follow this
1. Press F2+F4 at same time
2. password: 1 Alpha Alpha 66831
3. press more left purple key 2 times
4. press f3 and remove all for ram file and flash file
Mar 17, 2010 | VeriFone Omni 3700
Need to reprogram a vx 570 but don't have password, I believe it was programmed thru NorthAmerican Bancard. 1 alpha,alpha 66831 works on first entry but not for the 2nd password entry. Does anyone have a...
Try calling their support number. I had a non-standard terminal config password on an omni 3200. I called the processor's support line and they were able to give me the password.
Nov 24, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
I can't figure out the password for the settings?
If it is not - 1, Alpha, Alpha, 6, 6, 8, 3, 1 - then processor that had done a full download into the terminal had changed the password. And if you cannot get it from them, the only thing left to do with it, is to send it to VeriFone to restore the unit to factory settings.
Aug 11, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Verifone omni 3750
Use this Master Password from the manufacture #23378463
May 02, 2008 | VeriFone Omni 3700
Retail Supplies Logo
347 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
