Question about Uniden Cordless Phone
I just recieved my Uniden corded phone and two handsets. I have them all set-up. It did't come with a manual so I don't know how to set-up the answer machine and the time on it. Can you help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Select the model of your phone from the list at
http://uniden.com/index/manuals_results.cfm?cat=63
Posted on Jun 06, 2011
Need a manual
Since you declined to specify the model of your Uniden cordless phone, I can only suggest you select it from the list beginning here to download a copy of the manual. If you don't know the model of your phone, click on the "How do I know my product name or model number?" link on that page.
May 26, 2012 | Uniden 5.8GHz Cordless Phone
I have a uniden 6.0 handset phone d1660-2 and i don't know how to get my messages and then delete them
Select the model of your Uniden DECT 6.0 system from the list beginning here to download the manual.
Feb 03, 2012 | Uniden DECT 6.0 Cordless Phone ID
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
UNIDEN DECT 6.0 don't have manual need to
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Sep 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
I bought a cordless uniden phone DCX 640 on craigslist. it came with an extra handset. My problem is that there is no owner's manual so I don't know how to use the many buttons on the phone base. ...
Your phone's owner manual can be downloaded from this location.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Jun 20, 2011 | Uniden Cordless Phone exai398i
Uniden 6.0 answer/base/ cord less message set up
Thanks for using FixYa.
Please let us know the complete model number of the phone.
May 15, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
