Question about Viking 36 in Designer Series Freestanding Counter Depth Bottom-Mount Refrigerator - DDBF036
I have a viking Refrigerator Counter depth with bottom freezer. The condenstaion pan fills up and overflows every several months. Now the refrig. will not cool. I am not sure if they are related. Any ideas. I read your page here and it sounds like maybe the freezer is iced up?
  • 1,340 Answers
I would defrost it first, while you are defrosting it clean the coils if it has them some fridges its incorporated into the outer skin of the fridge ,you want oil the fan in the freezer and make sure the (if it has ) coil fan is working.. wipe the inside down dry ,a fan helps speed things along during the defrost, cycles defrost can get screwed up if you have left the door open on the fridge,unscrew light bulbs and put them to the side(to see if this is part of the problem, instal them the next day.check switches to make sure they turn off ,door closed) or it is in high use in high humidity area,hot pans,food.. vikings are a kool product , but only do what there made to do. if you try to use this for food service (commercial) it's going to be a pain, viking makes ones for that app... hope this was of help..jay the electric motor repair guy in longwood florida
Posted on May 26, 2011
Ice collects in the bottom of the freezer not allowing door to shut
BA Baker... hello,
Ice collecting on the bottom of the freezer.. is not such a terrible thing...
(Probably means the defrost is working... (merely not EXITING)).
New refrig or unfamiliar refrig could cause deeper analysis...
but if ...
If this is not a new device... and has been happily tending to it's own needs (evaporating well) for a while (months would be re-assuring)...
Then you are MOST probably looking at a clogged evaporator drain... (usually easily fixed by negotiating "WARM" (not hot) through the bottom vents slots of your freezer section.
Looking under your Refrigerator/Freezer... or consulting your owners manual... Locate your defrost "catch" pan...
It should NOT be dusty...
(easily tested: clean paper in tray...
Still clean tomorrow = clogged drain (pan is watered daily).
Close inspection should reveal a tube descending into it.... This is where you will watch for your patiently applied doses of warm water to appear... (near immediate).
It may take several doses... because ice can also have formed over the drain... Be persistent... You will be proud.
Please comment me back... I really like REFRIGERATORS/Frzrs...
few appliances tend to themselves so well (adorable).
Samsung RF4287HABP User Manual
Apr 17, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
My refrigerator is beeping and has high temperature both (freezer 30F and refrig. 58F). I try to set to default, but it didn't change.
your coils down at the bottom may be dirty & full of dust vacum it out. if the there is ice forming in the freezer it needs to be defrosted.
Oct 28, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
The drain pan at the bottom of the freezer side is overflowing.
If your water filter is " thru the kick plate , at the bottom , replace the filter . I have found several times now , where the filter rubber seals , have leaked into the drain pan , causing it to over flow . You do not have to replace the filter housing , just the filter .
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water is leaking from bottom on the side of
sounds like you may want to check your condensation pan which may be full and causing overflow each day.
Aug 14, 2009 | Amana ABB1927DE Bottom Freezer...
The freezer is not cooling and refrigerator is not remaining cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfgmjfmkxf
Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Can't find drain pan for Whirpool bottom-mount refrigerator
it should be under neith the unit or in the back on top of the compressor.
Mar 26, 2009 | Refrigerators
Defrost pan keeps overflowing
On the freezer side at the bottom of the freezer coil there is a drain. There should be a thin aluminium filiament attached to the defrost element and feeding down into the drain tube. This filiament conducts heat from the element down the tube preventing ice forming in the tube and keeping it clear.
Mar 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Viking 36 in Designer Series Freestanding Counter Depth Bottom-Mount Refrigerator - DDBF036 Logo
266 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Jim Y
Jim Y
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
