Question about Interactive Magic Liberation Day for Windows
How to get liberation day to play, says problem with 'global data'
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
Does whatsapp use data to send texts?
Yes, whatsapp uses data to send text. Yes, you need global data to use whatsapp in UK. Alternatively, you can purchase a local UK sim card with data provided your handset is unlocked.
Aug 28, 2014 | Apple iPhone Smartphone
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
I was sampling some German movies and notice they are more liberal than there Hollywood counterparts?
European social structures and behavior are far more liberal than Hollywood's. I don't think in censorship. I think personal responsible behavior as being a required preventive to exactly what is wrong for a community to openly view as to exactly what is being seen within the privacy of a property. In a free of charge society, we can't enact laws morality. My differences might contrast with another person's rights to even produce liberal film scripts. My selection is I'll just not enjoy them. Or maybe I will certainly ...
Top quality and discounts for the old German Script
Sep 08, 2012 | Computers & Internet
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
I sent my notes and to-do notes on my e-mail address but i didn't receive it? any way i could copy the data to my pc?thanks!
Good Day,
The best way to move / copy or transfer data from your phone is to use Nokia PC Suite or OVI suite.
There are several features on that software that is to be installed on your computer, one of which is backing up or manually transferring or copying needed data from your phone to your computer.
Please go to this web page to download the Nokia Installer. You also need the USB data cable for connection. Or you may also do the connection wireless, through Bluetooth Connection.
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Ovi_Suite_webinstaller_ALL.exe
Thank you for using Fixya.
Jul 10, 2011 | Nokia 5630 XpressMusic Smartphone
I can see the video on youtube and my compute plays cd's&, dvds,with volume. i hear volme when the computer is turned on and off. It's only when i go to youtube that my volume do not work
Hello and Welcome to FixYa!
Kindly follow this;
  • Visit YouTube, play any video
  • Right Click on the video and click Settings
  • A dialog box will open, click Advanced..
  • A new web page window will launch loading Adobe - Flash Player - Manager. On the left pane, click on "Global Storage Settings Panel" link under "Flash Player Help Settings Manager" sub-section under "Table of Contents" section.
  • Check (tick) the "Allow third-party Flash content to store data on your computer"
  • Now try to run the video again.
If it doesn't work also do this;
  • Right click on the video screen and hit settings then disable video acceleration.
If it still doesn't work, download and install CCleaner and follow the instructions to clean all the junk data.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Jun 11, 2011 | Computers & Internet
I can not restore my inspiron 2650 to its fatory settings
There are several ways to restore your Dell PC to factory settings.
Are you looking to just undo something that happened a day or two ago and not loose any data?
You can try the windows system restore.
Start>Programs>Accessories>System Tools>System Restore.
The other option is to back up your data and pics then while your laptop is booting up hit Shift and F11 repeatly and follow the dell system restore prompts.
Here is the XP instructions:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=RC968571&dl=false&l=en&s=hea&docid=70439310FC29784BE040AE0AB7E116BD&doclang=en
Here are the Vista instructions:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=RC968571&dl=false&l=en&s=hea&docid=34467C630F9E5F24E040A68F5B284ECB&doclang=en
Enjoy!
Nov 22, 2009 | Dell Inspiron 2650 Notebook
Interactive Magic Liberation Day for Windows Logo
149 people viewed this question
Top Interactive Magic Video Game Consoles & Games Experts
James Wishart
Are you an Interactive Magic Video Game Console and Game Expert? Answer questions, earn points and help others
