Question about Danby DDR4588EE Dehumidifier
The humidifier is working but the water is going inside the appliance and not in the bucket?
    Brigadier General:
  • 4,736 Answers
The drain hole or tubing that goes into the bucket is clogged. To solve this, you will 18" long plastic Zip Tie or something similar (NO Wire Coat Hangers) that is appropriately sized to fit into the hole. To access this drain hole or tubing, remove the bucket and look in above where the bucket came out. You will see a hole or plastic tubing. Insert the Zip Tie carefully and work it in until you reach a bend in the tubing. You must gingerly work it past this bend and continue pushing it in, until it either bottoms out or your run out of workable Zip Tie. Then while rotating it, slowly pull it out and be prepared for some water to follow.
That should solve the problem. Please let me know. Thanks.
Posted on May 26, 2011
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 18, 2011 | Haier Dehumidifiers
Our maytag and dayton humidifiers all starts but no water collects in the bucket.
heatman101
Jul 02, 2011 | Maytag Dehumidifiers
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
25BSRO humidifier want collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 13, 2011 | Whirlpool AD25BSR Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Danby DDR4588EE Dehumidifier Logo
246 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
