Question about Kenmore 63942 Dryer
My Kenmore 80 Series Dryer Model 110.96584120 has 4 temperature selections: low, medium, medium-high, and high. No matter which setting is selected on the switch, the dryer seems to only be drying on high. Is the problem in the temp selector switch or somewhere else?
3 Suggested Answers
  • 198 Answers
SOURCE: Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
Posted on Sep 03, 2009
  • 1122 Answers
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Posted on Feb 03, 2010
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 | Cell Phones
Dryer is shrinking clothes on low heat
is this a traditional kenmore dryer. Check your temperature selection switch in your counsel. It should have a small resistor on it. It should read about 10 ohms. if not than change the switch. That resistor is used when you set your selector on low heat. if it checks oout ok, the i would check your thermostat on the bottom panel. Like i said if this is a traditional kenmore dryer. You didnt really give a model number or brand of dryer. but if its a kenmore, try checking it out with a multi meter.
Jul 29, 2009 | Dryers
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryer exhaust temperature
on high turns off at 155 medium high 150 medium 140 low 125 extra low 105 all theese are plus or minus 10 degrees
Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Kenmore 63942 Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
