Question about Roper RUD3000GQ Dishwasher
Clean light keeps flashing dishwasher wont do anything
  • 5,911 Answers
If this is a Whirlpool manufactured dishwasher (such as Roper), the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back and let me know
Posted on May 26, 2011
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
The clean light keeps FLASHING and i cant clear it, and it wont let me do anything any ideas?
The unit has gone through a wash cyc and not acheived it set temp to warm the water the unit is in fail mode remove the bottom panel under the door you will see a tech sheet look at diag chart for clean light reset its something such as push high temp wash ---- sani buttons 3 times within 5 sec's to reset failure.
Dec 24, 2010 | Dishwashers
My dishwashers normal light keeps flashing and wont do anything
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Aug 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Flashing clean light
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
Indesit dishwasher DI 450 wont work
I had this problem and you have probably resolved it by now but I thought i would respond so that anyone else searching would get some help!!!
If program 2 and 4 are flashing it means that the filter is clogged and needs to be cleaned. Switch the dishwasher off - take out the filter and clean it and ensure all debris removed from in the filter housing. Pop it back in and switch back on and now the machine should work.
Mine is now running good as new!!
Aug 18, 2008 | Samsung 24 in. DB5710DT Stainless Steel...
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Dishwashers Logo
129 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
