Question about Toshiba Televison & Video
Can i get analoge tv on this toshiba 22AV615DG
Can you connect a hd converter to a Toshiba cx 32 g60 tv
there isn't much point in connecting an hd converter the toshiba cx32g60. the tv can only support an sd signal (composite video or ntsc analog). however, many hd set-top boxes (dvd players, cable and satellite) have composite outputs. these can be connected to your tv. blu-ray videos can't be watched with this tv. (the hdcp (high definition copy protection) can't be sent through most converters.)
if you want to watch ota programming , the cheapest option would be to find an sd digital-to-analog converter. these were the ones sold when most stations switched to digital tuners. some are being sold off as people replace their old analog sets. there are some hd tuner boxes, like this one: http://www.solidsignal.com/pview.asp?mc=03&p=3500stb&d=iview-hd-dvr-receiverconverter-box-for-tv-antenna-qam-%283500stb%29&c=digital%20converter%20boxes&sku= , that have composite video output which will connect to the cx32g60.
i hope this helps.
cindy wells
(if you tried an hdmi to component video converter followed by a component to composite video converter, the signal may degrade excessively.)
Jan 22, 2015 | Toshiba Televison & Video
Does my toshiba have a built in converter
The Toshiba 46G300U TV has a built-in Digital QAM, ATSC & Analog NTSC TV tuner.
Apr 01, 2013 | Toshiba 46G300U TV
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Is my toshiba CF35E50 a digital tv
This TV only has an analog tuner. You will need a set top box (digital to analog converter) to watch OTA TV.
I hope this helps.
Mar 22, 2011 | Toshiba Televison & Video
How do I reprogram tv for use without cable?
Ur tv is an ANALOG tv,all tube tv are analog tvs.Must buy converter box to convert to Digital Signal to get DTV.Buy this converter box any retailers like Target,Walmart stores
Feb 23, 2010 | Toshiba MD14FP1 14 in. TV/DVD Combo
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Toshiba TV model 19A24
THAT IS AN ANALOG SET. YOU NEED THE CONVERTER BOX. FOR TRANSITION TO DIGITAL.
Jan 22, 2009 | Televison & Video
Digital or analog?
As long as you are on cable you will not need a box.
Mar 28, 2008 | Toshiba CF19G22 19" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
