Question about Garden
I have a Toro mower with a tecumseh engine. It starts , but will not run. I am considering buyibg a conversion kit to propane. What is your opin[on?
    Novelist:
    Champion:
  • 222 Answers
I did a Toro the other day and got this straight from the Toro Distributor, or I'd have never fixed mine. When you remove that float bowl brass bolt, there is the usual hole down the middle and the two holes on the bottom sides. BUT, there is another hole that is so tiny you cannot see it and that is "What goes wrong with these mowers every time" (Toro Guy's words). Right at the very top of the threads on that bolt, there is a pin hole that the only thing you will fit thru it is the tiny wire that the needle valve hangs on. You must unplug that hole and clean it well with carb cleaner or your mower will not run. Good luck!
Posted on May 26, 2011
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 | Toro Garden
Toro recycler 20017 is very hard to start. it has to be primed many times. after it run a while it starts on one pull.
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
Apr 03, 2011 | Toro Power Lawn Mower
Where is oil drain plug on toro 22'' mower- tecumseh engine
IF you do not see the drain plug o the side of your engine, than most likely it is located on the bottom of the engine you will most likely have to remove the guard that covers the belt if you have self propelled lawn mower and the plug should be under the guard. Good Luck
Jul 18, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Replacing a tecumseh carburetor on a toro
PartsTreeRepairClinic may have a video
Jan 30, 2018 | Toro Garden
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
Toro 6.5 Tecumseh Recycler won't stay running
I have the same mower and problem. Found out the issue was the carburetor. Pull the Carb and do a quick cleaning. Order the replacement kit prior to working on. My bowl o-ring was shot and I couldn't get a seal after cleaning it out.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
