Question about Lexmark X125 All-In-One InkJet Printer
Add right cart. in window I just put in a new cart. Recond. Now I can not fax.
  • Official Brand Answer
  • 3,344 Answers
Installing/replacing a cartridge should not affect faxing. There could be some connection that got disrupted. Make sure the telephone cord for the fax is properly secured into the printer and still connected to the fax line in the wall. Unplugging and replugging will the telephone cord will help secure the line.
Posted on Jun 02, 2011
What parts do I need to do a complete brake job on a 1998 Ford Thunderbird...front and back
1. Machine or replace rotors and/or Drums
2. New Disc Pads and /or Brake Shoes & springs for brake shoes
3. New or recond Brake Booster
4. New or recond Master Cylinder
5. New or recond Disc brake calipers and/or wheel Cylinders
6. Brake fluid
7. Check all the brake fluid lines for any damage
thats about all I can think of, hope it helps
Jun 18, 2010 | 1998 Ford Thunderbird
Just put a new toner cartridge in fax and now I get message saying "change drum soon" How do I fix this?
First make sure your toner cart is the right one for your machine.. Try another cartridge to verify that even though the cart is new does not mean it does not have a problem. I would check all the silver contacts on the drum unit to be sure they are clean. use 90% alcohol to clean them, using a cloth to wipe them.
Jun 08, 2010 | Brother IntelliFax-2820 Laser Fax
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
I just installed a new toner cartridge and now all my pages have a thick black line down the right side of every sheet.
the new cart mite be bad:(. Do you have a second cart? next cart placed in the machine properly? Look for a toner band on the drum?
Aug 13, 2009 | Brother IntelliFax-2820 Laser Fax
Printer tells me to install new color cart. after i have put in new hp cart.
1. Press the Setup button.
  1. Use the arrow keys to select Tools and then press the OK button.
  2. Select Clean Print Cartridge and then press OK . The device prints a test page.
  3. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  4. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  5. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
  6. Remove and re-insert, while the product is switched on.
If still bad, swap out the cartridge.
Hope this helps
Regards
Apr 19, 2009 | HP Officejet 7310 All-In-One Printer
I have cked all components....have cart and is not empty cleaned all i can.....my fax r too dark to read and the more i copy the darker they become.....HELP >:) Wm
What i have seen on other customers fax's that the toner cart. is bad. bot before you go put a buy a new 1. take the toner out of the drum unit, blow out the drum unit with can air or compressor, ( Do this out side or some place where toner is not a factore ) slide the blue or green slide lever move it back an Fourth bought 15 times put the toner back in, tray it, if not then tray new toner, if not then the drum unit, hope the cheaper works out for you
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
HP 20 ink refill problem
Did you try a new ink cart? Most print problems with inkjet machines are refilled carts.
Nov 18, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark X125 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
