Question about Samsung HP-R4272 42 in. Plasma HDTV
Samsung HP-R4272 tv has been working fine for the past 4 years. now the tv picture is blank but the power supply is ok and the audio is fine too.
  • Samsung Master
  • 3,459 Answers
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on Jun 10, 2011
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung HP-R4272 42" plasma. 3" blue/ green ribbon
This is caused by the LCD panel shifting in it's mounts. You will need to disassemble the frame holding the LCD screen in place and re-center it.
The lines will take some time to go away as the set warms up, but be patient, they usually disappear over time.
Oct 26, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Picture will not come on.
I found this in the user manual. From what you've said I would check the second paragraph first. I hope this works for you.
On your computer check; Power, Signal Cable.
The TV is using its power management system.
Move the computer’s mouse or press any key on the
keyboard.
On your equipment check (STB, DVD, etc) ; Power,
Signal Cable.
Press the Source button on the panel or remote control.
Turn the TV off and on.
Sep 24, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Open Questions:
See all Samsung HP-R4272 42 in. Plasma HDTV Questions
Samsung HP-R4272 42 in. Plasma HDTV Logo
312 people viewed this question
Henry  Thomas
Henry Thomas
